Question about Panasonic KX-TG2336S Cordless Phone
I have a panasonic KX-TG2336S cordless phone and when you try to make a call the handset displays "no link to base". Can this be fixed or is the phone shot?
  • YJohnChen Feb 26, 2009
    After the 20 secs, the display showed "ERROR" ... so the phone is really junked?
  • Panasonic Master
  • 2,460 Answers
Just in case you don't have a manual
http://service.us.panasonic.com/OPERMANPDF/KXTG2336.PDF
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Carl
Posted on Jan 19, 2009
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
I have the below-mentioned problem with my Panasonic Cordless model KX-TG3531BX No link to base. Move closer to base, try again. Please contact me on 9879590311 or email me at ritu_vpatel@yahoo.com
place all handsets in the base unit for about 1 minute each. This links the handsets to the base. Sometimes the handsets lose their link to the base unit. If this doesn't work try to call Panasonic tech support for further information, the phones could be defective as well.
Aug 30, 2009 | Panasonic KX-TG5632 Phone
One handset works, the other displays
Pull the battery out of the afoul unit. Let sit for 5 min. Put battery back in unit and set it in the base unit.
Feb 28, 2009 | Panasonic KX-TG1033S Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic KX-TG2336S Cordless Phone Logo
495 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
