Question about Nokia C201 Cell Phone
I have Nokia c2-01 and some missed calls, dialed calls and received calls are delete and fix in mobile... i have reset it many times but it does not work.. now what i have to do..? please help me?
Raysagem
  • 1017 Answers
SOURCE: Nokia N95 wont display Log
Resetting to factory settings will probably sort it out. But you might loose the data stored on the phone. You'll find the reset in the menu, tools, settings.
I'm assuming that you switch your phone off sometimes, if you don't, try a restart first.
Posted on Feb 11, 2008
SOURCE: Nokia 6610i Display not working
6610 i lcd problem
Posted on Feb 05, 2009
nonontech
  • 4737 Answers
SOURCE: i have Nokia N-72 cell phone. Now i m facing
There are several reasons related to this problem, like virus, message memory storage, phone memory full, etc..
First remove your memory card and check whether the error is still there or not. If so, try to delete files from your phone memory, like sms, songs, bluetooth received files, photos etc..
If there's not error, after the memory card is removed, then check your memory card, if possible scan it and try again. I would suggest you to format it after backing up the files, contacts, etc...
Set the message storage to your memory card directory not your phone memory. If you have problem doing this, please let me know so that I can assist you.
Good luck..
Thanks for using FixYa.
Posted on Jun 14, 2010
  • 12 Answers
SOURCE: Hello, I have Nokia 6303i mobile.
actually the phonebook memory of this is limited u can now change ur destination to ur memory card then it works
Posted on Nov 06, 2010
  • 3 Answers
SOURCE: Call log getting deleted in Nokia E71
Try changing the setting to either a day or ten days that should help.
Posted on Jan 07, 2011
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Using my Nokia C6 phone , How i can delete a single entry from my call leg rather than delete the whole entries. for example how delete a single number from the recieved or dialed numbers?
Its easy. Just go to that call log. For instance, you want to delete XYZ's number from the received calls log, go to you recieved calls, scroll to XYZ, select 'options'. In the options, select 'delete'. You would be asked if you actually want to delete the number XYZ from the received calls log. Selecting 'yes' deletes the number.
You can do the same for your dialled and missed calls.
Hope that helped you?
Have a wonderful day.
Jun 20, 2011 | Nokia C6 Smartphone
Cannot delete dial,receive and miss call number!
Same thing happened with me I did a factory reset and it went away, so you will loose all your data if you do reset so be sure to make a backup.
Mar 06, 2011 | Nokia X3 Cell Phone
My nokia n73 cant send or recieve pic messages..why?
Hard reset your phone. This will delete all the content of your phone so remove your memory card before resetting your phone. On the home screen type *#7370# .
Nov 02, 2010 | Nokia N73 Cellular Phone
Memory low
I had this problem before with my Nokia N73.
(After 3-4 hours on hold to various nokia helpdesk operators...) The problem turned out to be that I had too many SMS/MMS messages stored.
I deleted them all, and the problem resolved itself!
Give that a try, and let us know if you need any further assistance!
Jun 22, 2009 | Nokia N73 Cellular Phone
My mobile cant receive any new massages
try deleting some messages
it sometime happens due to less memory
may be ur sim memory is full
Feb 10, 2009 | Nokia 6600
Jan 20, 2009 | Nokia E71 Smartphone
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Nokia C201 Cell Phone Logo
249 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
