Question about Lennox WB2-17/WP2-18 Humidifier Replacement Water Panel
Water flooding from humbifier heavy climate wb2-17
Flooded basement from until
Why am I getting water blowing into the furnace and flooding the floor? This is happening after 12 years of service.
Hello, this can be either a clogged drain line or the tubing supplying the water into the humidifier is cracked. The size of the house has nothing tomdo with the water leaking into the Furnace.
Jan 04, 2013 | Aprilaire 550 Humidifier
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
Dehumidifer runs, but does not collect water. Just started this recently. We use it in the basement. Not too old. It's a Whirlpool Accudry.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 07, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
The unit is leaking water, but not from the collection bucket. The unit is in the basement, has worked well for many years, but has never been serviced or cleaned.
More than likely, the drain tube or hole that delivers the water into the collection bucket is clogged. To clear the clog: First turn the unit OFF and unplug it from the wall outlet. Use an 18 -20" long plastic Zip Tie, that will fit into the drain tube or hole. DO NOT use a wire coat hanger for this. Carefully insert the Zip Tie into the hole or tube and gingerly work it in until you reach the bend of the tube. This is where it gets a little tricky, because you must get past that bend, to be effective. Once the Zip Tie has reached it's limited reach or it has bottomed out. Slowly pull it back out, while rotating it. This will remove any clogs, so be prepared for water to follow.
Hope this helps you solve that leaky situation. Please let me know.
May 06, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
My humidifier is not working. I have cleaned the heating element. When plugged in the green turns on but that is it. The elements are not heating up to begin the vapor process.
Add salt. No more then 1/2 to 3/4tps max depending on the mineral content in your area.
The unit has two electrodes dipped into the water. Since water its self is none conductive without heavy minerals such as iron and such. You will have to add a small amount of salt until current starts flowing between the electrodes. I suggest a small pinch of salt each try until it produces the steam effect you desire.
Dec 22, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
Leftover water in the base was hot in the morning
If there is not much leftover water, you don't have to worry much about it. However, if the leftover water is
somewhat flooding the area where it was located, it is a
different story, there is a leak and it must be corrected.
Check for leaks in the water container, so that operates
normally. Hope this will help you.
Jan 10, 2010 | Kaz 5520B Humidifier
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Leaking humidifier
Check for an obstructed drain line.
Feb 28, 2008 | Aprilaire 700 Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Lennox WB2-17/WP2-18 Humidifier Replacement Water Panel Logo
60 people viewed this question
Top Lennox Humidifiers Experts
Mack Baxter
Dennis
Are you a Lennox Humidifier Expert? Answer questions, earn points and help others
