Question about Samsung Televison & Video
My TV Samsung Model # LN26A450C1D has sound when you first turn it on but takes a few minutes before I get a picture. What's the solution.
Model # LN26A450C1D Model Code LN26A45C1DXZA
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
  • 7 Answers
SOURCE: tv wont turn on
Mine was doing that then it quit even turning on too so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
SOURCE: Samsung LCD TV, no picture only sound
My Samsung LNT4669F has two problems..the first is that it takes about 3 minutes to turn on. The red light at TV bases flickers on and off but the sound is there back and forth..Finally, the wite light at base turns on and the TV makes a noise as if it just got turned on and it stays on..why does it take so long?
Secondly, sometimes, the HD channels flicker so badly that I cannot even watch TV..so badly that sometimes the picture is blank..however, the regular channels are fine..Can you help?
Posted on Mar 08, 2010
SOURCE: My Samsung LN26A450C1D was turned off one night at
I have the same problem.
Posted on Mar 28, 2010
freelance-au
  • 131 Answers
SOURCE: clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Posted on Apr 05, 2010
Ln26a450c1d samsung picture problems
Requires servicing right from cleaning inside thoroughly, cleaning switches, connectors, resolving all dry solder, replace all leaky or dry/short capacitors. It is a job to be done by a qualified service technician. Anyhow, before hand, just check your power outlet and ensure there are no loose contacts on outlet, power cord etc. and there is enough voltage required. Then connect the TV to any other device to rule out possibility of a defective input device.
Aug 12, 2012 | Samsung LN26A450C LCD TV
LN26A450C1D
Change the input to some other device and if you see same problem, there is something wrong on the PCB inside. It is better to show it to a qualified service technician.
Jul 14, 2012 | Samsung LN26A450C LCD TV
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Samsung t.v. picture going in and out
it may sound like you have a input or a output problem if you have a video un plug it from the tv. and put your Aral strait to your tv that will tell you if your video is the problem not the tv.
Jan 07, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
6,968 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
