Question about Garden
Saw will not go full throttle when cutting in cold weather
Seems boggy while cutting
    Problem Solver:
  • 30 Answers
You may need to adjust the carb.
Posted on Jan 01, 2013
3 Suggested Answers
  • 9 Answers
SOURCE: Chain saw will not take full throttle. w4018wt
You need to clean the air filter. and make sure your using the proper fuel mix.
Posted on Aug 27, 2009
  • 4088 Answers
SOURCE: my poulan 360a chainsaw cuts out when used for 5
Check the fuel filter for plugging, the fuel lines for hardness/cracking/splitting. Clean or replace the air filter. Clean the muffler if plugged. Make sure that the carburetor fasteners are tight. Check the spark plug condition--gap should be 0.020" and the insulator should be light to medium tan color. If still having problems, the carburetor may need to be cleaned and serviced. Hope this helps!
Posted on Apr 22, 2010
How do i set air on husky 435 saw to fix boggy runnin
Mitch:
Adjust the fuel and air mixture screws while the saw is running... you'll find that "sweet spot"... it just takes a little patience! Small adjustments... If you over adjust and the saw quits running or starting, GENTLY turn both screws in all the way (don't damage the needle valves or seats) and turn both out one and a quarter (1 1/4) turns out. The saw should start, then adjust from there.
Jan 01, 2013 | Husqvarna GAS CHAIN SAW 435 16"
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
It cuts out at full throttle.
Check the muffler and air cleaner for plugging. Try turning the H jet needle CCW about 1/2 to 3/4 turn which should make it 4-stroke at full throttle. Proper setting is for the engine to 4-stroke at full throttle, but immediately 2-stroke when cutting. (CW turning of H makes it leaner) See a Poulan servicing dealer for a rebuild kit. Be sure to check the fuel filter in the tank for plugging. Hope this helps!
Apr 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw starts but dies when throttle is touched
This is a normal response if the engine is cold. Make sure that it is warmed up by using partial choke. If it still has problems, check the fuel lines and filter (in the tank) for condition, the carburetor is mounted tightly and all of it's screws are tight. Make sure the air cleaner is installed correctly. Make sure the muffler is not clogged. If none of this helps, try turning the L and H needles on the carburetor about 1/8 turn each CCW (choke off). The L needle should be set so that the engine will 'follow the throttle'. The H needle should be set so that the engine 4-strokes at full throttle, yet immediately 2-strokes when cutting. Hope this helps!
Mar 17, 2010 | Husqvarna Forest & Garden No.967012396 345...
Idle seems too low. runs great, when no throttle, stalls. maybe idle too low. no manual, need to know where idle adjustment screw is
If you haven't already adjusted the carb there are usually 3 adjustments. H - adusts performance at full throttle (how it cuts in the wood). L - adjusts performance at idle and accelleration to full throttle.It sounds as though those are fine. The third adjustment T - is the throttle or idle speed (often away from the other 2). If my saw that is the one adjustment I'd make. You supplied no make or model, it is difficult to provide what you requested without them. HTH
Lou
Oct 27, 2009 | Garden
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Jul 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine stalls
Sound like the clutch is not disengging. The springs in it are likely week. Take note as to weather the chain stops when it is idleing. If it seem to idle at a reasonable speed and the chain does not stop turning, the clutch is most likely the problem. This problem can be caused by trying to work the saw without the throttle wide open. When the clutch slips it creates heat wich will over heat, and weeken the springs used to disengage the clutch. It is also possible that it was defective when new.
Jan 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
