I need to change my tax rate to 7.5% but I can't figure out how
SOURCE: hi I need to change my registers tax rate
http://www.sharpusa.com/files/cas_man_XEA40S.pdf is the link from the previous answer to this problem. According to the manuals on line for cash (which was pretty reasonable at around 5-6$ the 40s and 41s use the same manuals.
hope this helps, Dave
SOURCE: programming all department keys for tax
Page 34 item 2 "Tax Programming for Automatic Tax Calculation Function" in the manual. You can download the PDF version of the manual by clicking the link below:
SHARP ELECTRONIC CASH REGISTER MANUAL XE-A404
There you go... :) Please rate me for this answer.
SOURCE: i just bought XE-A402 cash register how do i set just one depart ment as no tax, for labor
You need to check the tables in the department programming section of the book. There will be a setting for tax or non tax for each tax number. So if you need to turn off tax 1, set tax 1 to non tax. See how you get on.
If you need a manual, C-tech have one here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A402_operation_manual.html
SOURCE: sharp cash register xe a41s tax programming
The two main programs to edit are the tax rate program and the department program. have a look at these tables in the manual and set your tax.
If you need an XE-A41S manual, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A41S_programming_manual.html
