Question about Sharp Royal Alpha 9155SC Cash Register
Set tax rate royal alpha 9155sc cash register
I need to change my tax rate to 7.5% but I can't figure out how
5 Suggested Answers
SOURCE: hi I need to change my registers tax rate
http://www.sharpusa.com/files/cas_man_XEA40S.pdf is the link from the previous answer to this problem. According to the manuals on line for cash (which was pretty reasonable at around 5-6$ the 40s and 41s use the same manuals.
hope this helps, Dave
Posted on Aug 02, 2009
oakwoodman
  • 36 Answers
SOURCE: programming all department keys for tax
Page 34 item 2 "Tax Programming for Automatic Tax Calculation Function" in the manual. You can download the PDF version of the manual by clicking the link below:
SHARP ELECTRONIC CASH REGISTER MANUAL XE-A404
There you go... :) Please rate me for this answer.
Posted on Aug 28, 2009
Electroboy
  • 1660 Answers
SOURCE: i just bought XE-A402 cash register how do i set just one depart ment as no tax, for labor
You need to check the tables in the department programming section of the book. There will be a setting for tax or non tax for each tax number. So if you need to turn off tax 1, set tax 1 to non tax. See how you get on.
If you need a manual, C-tech have one here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A402_operation_manual.html
Posted on Nov 23, 2011
Electroboy
  • 1660 Answers
SOURCE: sharp cash register xe a41s tax programming
The two main programs to edit are the tax rate program and the department program. have a look at these tables in the manual and set your tax.
If you need an XE-A41S manual, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A41S_programming_manual.html
Posted on Aug 19, 2012
Reciept side ink not printing
Need a new ink cartridge. Just like any printer they do not last forever before it needs changing and faded ink is classic sign that is the case. Skipped spots but good darkness would indicate some thing is dirty instead but that is not your situation.
Apr 15, 2015 | Sharp Royal Alpha 9155SC Cash Register
Royal alpha 9500ml
Head up. On your printer press down the green unit.
Aug 21, 2014 | Sharp Royal Alpha 9155SC Cash Register
How do I put the commercial message at the bottom of the receipt? 9155sc model
AS you programed the logo. Just go to line 7-10 . thats for the botttom
Mar 01, 2014 | Sharp Royal Alpha 9155SC Cash Register
MY 9155SC REGISTER WILL NOT TURN ON
Turn you key to HALF PAST then switch it on then turn the key back to reg. If it does not turn on call a technician
Feb 13, 2014 | Sharp Royal Alpha 9155SC Cash Register
Scanner trouble
It sounds like you have lost the port settings. Most registers have to have the scanner port (socket) set in programming so the register knows which device you are using. I haven't worked with this model but if you need a manual, one of the users has a Royal 9155SC manual here:
http://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-9155sc_instruction_programming_manual.html
Jul 10, 2013 | Sharp Royal Alpha 9155SC Cash Register
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
I need to change the tax rate on a royal alpha 600sc
To program a sales tax rate of 6%
1 Find your sales tax rate. You may need to contact your local government
office.
2 Put the PRG key in the Mode key slot and turn it to the PRG position.
3 In the round Number keys area, press 1 and then press the Tax 1 key.
4 Press 6000 and press the Amount Tend Total key. Your sales tax is
programmed.
Apr 01, 2009 | Royal DM3070
ROYAL ALPHA 587 CASH REGISTER
Try this, for example june 30 2004 =
Put the mode key in PRG position In round number keys press 063002 then press #/ST/NS key
If that works to set the time in round number keys press 1100 then press Qty/Date or 1305 for one 05 pm. I have a 587 cx and can't fiqure out how to print my reports X Z
Aug 21, 2008 | Office Equipment & Supplies
Sharp Royal Alpha 9155SC Cash Register Logo
263 people viewed this question
Top Sharp Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
