Question about Nintendo Wii Console
My wii turns on and takes the disc but then just makes a whurring sounds and isn't even acknowledging that there is a disc in.
    Novelist:
  • 174 Answers
This could be the mechanism is bent, a spring is loose or you might have not seated it right (if you have been inside it).
let me know if you get it done, if not i can fix it for you at a reasonable price. www.fixmyconsole.co.uk
Posted on Jan 18, 2009
Pontiac montana whurring sound, constant while in motion
Drive until the sound appears and move the steering wheel left and right a little.Can you change the sound at all?If so it's wheel bearing time.
Jul 02, 2017 | 2006 Pontiac Montana SV6
I am getting a sound like i have winter tires on coming from the rear of my 2005 Mercury Montego almost sounds like stuck in low gear.
SOUND LIKE FAULTY WHEEL BEARING IF NOISE SOUND LIKE WHUR WHUR WHUR WHUR NOISE WHEEL BEARING NOISE.
Nov 10, 2011 | Cars & Trucks
Wii game was stuck halfway in machine kids couldn't get it to go in so they tried to force it till I caught them and stopped it. Pulled it out and when you try to put a disc in there is a grinding...
The best option to fix this problem is to take it to a service center unfortunately, but here are a few question you need to know the answers for to be able to get the best service:
1. Was the Wii on when they tried to force the disc in? If not then the noise could be that the motor mechanism has been jammed and the worm gear for the motor has been stripped. You will need the disc ejector mechanism replaced.
2. Was there another disc in the machine at the time? If there was, it is possible that the first disc has become lodged in the machine and could have been broken into pieces, so when the disc is entered or ejected, sometimes it will go in and sometimes not. When there is vibration the disc pieces or even the whole disc could move in and out of the way of the tray. You would also need to have this removed by a service technician.
Wii consoles are notoriously fiddly to deal with when it comes to repairs, needing special screwdrivers and a keenly trained eye to be able to spot a problem in an extremely confined space.
I'm sorry I could not be of more help but I hope this helps you even a little.
Jul 15, 2011 | Televison & Video
Why isn't my wii reading my game discs
If it is having problems reading game disks, it sounds like the laser that is used to read the data might be dirty. I would recommend purchasing a Wii Lens Cleaning Kit (which is also available at many retailers such as GameStop, WalMart and Best Buy) and see if that makes the system run any better.
Jun 29, 2011 | Nintendo Video Game Consoles & Games
Wii could not read disc
There could be several things wrong. Let's start with the most basic - is the disc inserted correctly? The holographic side needs to be on the left when inserting it. Then, make sure there are no scratches or smudges on the bottom of the disc. A common solution is to wipe it with a cloth or even your shirt if you don't have one handy. Look on the holographic side of the disc to make sure there isn't anything left on it. After cleaning thoroughly, try playing the disc again.
If you're still having a problem, try restarting the Wii console. However, there's always a possibility that you have a bad disc or, if you're unable to play any games, a bad console.
Jun 01, 2011 | Nintendo Wii Console
WII system turns on and screen pulls up it just wont read the discs. dics are clean with no scratches.
A couple things could be happening.
Make sure you're inserting the disc properly as the Wii will accept the disc even if you put it in backwards. Make sure that the label side (the side with all the pictures) is facing toward the thin side of the Wii and the shiny side is facing the thick side of the Wii.
If that doesn't make a difference, then it's like a problem with the disc drive itself which can only be fixed by Nintendo or a repair shop. They'd have to take your Wii apart and possibly replace the drive.
Mar 25, 2011 | Computers & Internet
How can I hook up my Wii to my mothers TV? It is usually connected to my TV...I cant get the Wii to acknowledge the Wii remote at all.I even tried changing the batteries/remote but nothing. My 10yr old...
To get the Wii Mote Connected to your wii Take off the back cover of the Wii Mote, Hold down the Red button for a few seconds, Then on the Wii Console pull open the little door just under the Disc Drive and press the Red button on there. This will allow the Wii-Mote to "Sync" to a different Wii-Console
Hope This Helps.
Mar 19, 2011 | Nintendo Wii Console
Wii unable to accept/eject disc making buzzing sound
  • When the disks were put in/taken out the little plastic clips in side the wii may have broken off. Might be stuck near the motor. Gently shake while rotating the the wii with all the cords off with no game inside. listen for anything loose. If your lucky the piece will go to another part of the wii. Best thing is to find someone to take it apart to check.
Jul 14, 2009 | Nintendo Wii Console
Wii unable to read gamecube disc... :(
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Mar 23, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
16 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
