Question about KitchenAid KUDE60FXSS Builtin Dishwasher
What does clean light flashing 4 times means
Dishwasher will not start
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: KUDS model clean light flashes
This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Often, I have found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 17, 2009
Flashing orange fault flashes four times whirlpool
4 flashes on whirlpool diswasher usual means a draining problem clean out your filters
Feb 02, 2014 | Whirlpool Dishwashers
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Kenmore dishwasher clean light flashes 7 times
you need to change the switches on the door lock and put it in diagnostic mode to clear
there is 3 or 4 buttons on the right side of the control press the inside one then the outside one back and forth 3 or 4 time after the kights start flashing press cancel
Jul 03, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
KitchenAid KUDE60FXSS Builtin Dishwasher Logo
109 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
