Question about Dell Inspiron All-In-One Computer
All in one dropped on the floor and now won't come on
  • Dell Master
  • 998 Answers
Well if the display is damaged, it's a boat anchor.
Posted on Jun 25, 2013
1992 Dodge Stealth SOHC - no problems, running great, then I replaced the distributor (forgot to mark it) & now the car won't start up. It'll turn over, even got it to start once but won't...
put number 1 cylinder at top dead center and drop in distributor so the rotor points to number 1 on cap. may have to try several times as gear moves when lowering dist.
Sep 07, 2013 | Cars & Trucks
Won't shift into overdrive
Should be in overdrive & converter locked
at 42mph or about-- unless your flooring the gas
Internal Solenoid Problem or Valve Body Dirty
Jan 23, 2013 | 1991 Mercury Cougar
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Changed transmission also dropped the motor to do other work, now it won't start
as the engine & ****** have been disconnected from the ecu for a while i suggest that it is an ecu problem, & problems with the ecu can generally only be sorted out by a main dealer & the costs can run into thousands.
Sep 13, 2012 | 2005 Cadillac CTS
Clutch went to the floor
lost preasure at clutch check fluid level first.
Aug 21, 2011 | 2004 Pontiac Sunfire
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
I droped my 18 volt cordless B&D on the floor and
if it went to pieces when you dropped it, I'll just bet a manual won't help you, I'm thinking a case of super glue.
Jun 16, 2011 | Black & Decker 18 Volt Cordless Drill...
My PC recognizes my hard drive but it's making a ticking sound & it won't re-format. I'm running Win7 & have tried both reformat settings-NTFS and exFAT but there is not action at all....
I'm sorry to hear that your hard drive is having trouble. Based on your description of the "ticking sound" and the fact that the drive was dropped, the drive is probably physically damaged. Unfortunately, this means that your drive is failing in a way that isn't fixable; it will have to be replaced.
May 26, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Dell Inspiron All-In-One Computer Logo
Alun Cox
