Question about Magellan Maestro 3225 Car GPS Receiver
Incoming call sound won't stop on magellan 4200
When I turn the unit on the incoming call dinging sound starts and won't stop. If I turn the GPS off and then turn it on again it starts again. Is continuous.
  • 21 Answers
Press and hold the on/off button for 20 seconds.
Posted on Oct 07, 2009
2001 s10 will jump start. After it sits, I try to start it, it won't start, but the ignition keeps dinging after I turn it off and take the key out. I can jump start it and the dinging stops.
its sounds like a bad ignition switch-try to jiggle it and see if its stop after you have turned key off- also those dinging sounds are to warn you that you have left something on -usually headlights or maybe even your dome lights which would account for your battery dying
Apr 01, 2013 | 1998 Chevrolet S-10 Pickup
How do I update my Magellan 3250
You can go to Magellan's website but I can assure you there are no map updates for free.
Try resetting the unit.
Turn it on and find the tiny hole marked reset - -then push and hold a paperclip in the hole until it resets. Try this 3 times if you want to clear it out and start with the maps it came with.
Go here - the official Magellan website and read until you see the word RESET - this is for your model.
http://www.magellangps.com/support/faqdetail.asp?faqid=480&prodid=1948
Please rate me hi it makes a big difference to me - thanks
Rice
Mar 30, 2010 | Magellan Maestro 3250 GPS
My 4250 stopped talking. I ran the diagnostic
Probably a bad speaker, common problem with GPS units. Is there any sound at all, have you tried calling your cell phone to see if you can hear the rig through the GPS?
Try that and if you still can't hear anything it could be the speaker.
Feb 15, 2010 | Magellan Maestro 4250 GPS
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
MAGELLAN 3250 GPS - SPEAKER NOT WORKING
go into the menu and make sure the sound hasn't been turned off
Jan 21, 2009 | Magellan GPS
Magellan RoadMate 700 GPS
The most obvious question is, have you accidentally turned down the volume to a level where it can't be heard. There is a volume wheel on the unit. Also, there is a way that the sound can disappear if the unit gets "locked up". But that shouldn't be a persistent problem. Removing the power cord and reinserting it should clear that problem.
Dec 09, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan 760
sounds like your power dock is the culprit, not the internals, you can purchase one from circuit city or tigerdirect.
Sep 19, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Maestro 3225 Car GPS Receiver Logo
67 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
