Question about LG M4200C 42 in. HDTV-Ready LCD Television
Tiny horizontal lines blurring picture - no known trauma, but highly irritating.
Our TV is less than 1.5 years old. Recently, there are horizontal lines that make the picture blurry. This is especially noticable when there are words on-screen. These lines are present with the satellite feed, with DVDs and VCR tapes. Always.
  • 85 Answers
SOURCE: plasma with horizontal stripes.
buffer drivers could be it
Posted on Jan 15, 2009
  • 92 Answers
SOURCE: purple line down middle of screen
I could do with a digital photo to be sure, however it sounds like the LCD panel itself has failed.
Posted on Mar 28, 2009
  • 77 Answers
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
Posted on Jul 10, 2009
  • 1187 Answers
SOURCE: 1/2 picture on my vizio 42" TV
Are you under warranty? Chances are real good that you need the signal board....the one with the rca jacks and rf connectors. This may be pricey $$$$$ but will surely repair the problem.
Posted on Aug 08, 2009
  • 1039 Answers
SOURCE: I have a horizontal line going across the picture of my tv.
The panel is bad and will need to be replaced.
Posted on Dec 06, 2009
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Posted on Feb 05, 2010
0 characters
1 Points
Poor picture quality on alba LCD TV after recent digital switchover.
Digital TV uses less airspace than analogue TV, so after the digital switchover there'll also be more room for services such as high-speed mobile broadband and high-definition television (HD TV).
Sep 16, 2012 | Flat Panel Televisions
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
The sound is great, but the picture has gone to gray with horizontal white lines across the screen. It is 20 years old, and probably not worth fixing, but i will ask anyway, just in case it is a simple...
Hello Sat, hi, its a failure of the horizontal output transistor responsible for high voltage. This transistor is needed to be replaced. you need a TV tech guy to have this fixed. have it checked first, the trouble is common to CRT type TV really easy to fix. for a tech guy.
Dec 07, 2010 | RCA Flat Panel Televisions
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
My TV is less than two years old and out of
this tv needs a new ysus board and maybe the ysus buffer board as well..
type in buffer board for your model of tv in ebay and ysus,, theres a guy there who does them 64.99 & 12 £ postage u muct send your old one in,,for repair / replacement,,
6871QYH053B this is the ysus model u need..
all the best lee..
Apr 28, 2010 | LG 42PX5D 42 in. Plasma HDTV
My TV is less than a year old. It has white
Do these lines disappear after the set warms up a little? If they don't then you most likely have bad buffer boards(X buffer or Y buffer). Sometimes it is also caused by a bad panel. Since your tv is less than 1 year old and is still under the 1year manufacturer warranty I strongly suggest that you contact the manufacturer for repairs.
Contact info:
Phone: (800) 877-5032
Fax: (870) 630-4223
Please rate this solution if you found the information helpful.
Mar 29, 2010 | Sanyo DP50747 50 in. Plasma TV
12 little horizontal lines in Sony Bravia KDL-52W4100
It's the panel. Mine took a sharp force trauma when it fell only 1 foot onto something very pointy (a cellular external antenna) and it looks like it got shot by a bb gun. And it has lines kind like what you are describing.
You can't fix an LCD tv with this kind of problem. You just can't. The LCD panel cost more than a new TV. I know I asked the local Sony Shop to just order me the LCD panel. It was over $900 on a $600 retail TV. I was going to replace it myself ... I fix laptops ... but not at that price. So far I'm just using it as it is, until I want to, and have the $$$ to buy another one.
Good luck on yours.
(a laptop lcd panel repair costed over $300 by the way on a $600 laptop with a few years age on it. I did it mainly as a learning experience. But never again.)
Nov 23, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Jun 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Flat Panel Televisions
LG M4200C 42 in. HDTV-Ready LCD Television Logo
85 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
