The light on the power button does not turn on when I push the button in; I have tried all the troubleshooting from my computer. Do I have it plugged in incorrectly. It seems like there isn't any choice: one speaker has to be plugged into the other where it says "To L Spk" -- and the other speaker is plugged into the computer on the buttom of the three holes where this size plug can be inserted. This is probably stupidity on my part! Please help. Thank you. Nancy Hartford
Check out the speaker in another pc or connect other speaker to the pc and check out.also remove all the connections and reconnect it and check out.
Probably the power adapter has failed, check that its pluged in properly and reconnect it.
if the power adapter is fine, the board may have fried on the speaker and its not turning on.
The three holes which you r talking just insert that wire in all the holes 1 by 1 and check out.also connect the head phones and check out.also check the volume control setting in the task bar.it must be on mute.
