Question about Home
Toilet runs continuosly - Home
    Top Expert:
  • Home Master
  • 44,894 Answers
The fill valve may not be shutting off when the tank is full or the flapper valve at the bottom of the tank may require replacement. Replacement of both should cure this problem
Posted on Jan 01, 2013
  • Tony Giannone Jan 01, 2013
    Thank you, Tom. It turned out to be the flapper valve. It wasn't fully seating over the drain hole. I made an adjustment to stop the leaking but also ordered a new flapper valve to replace the old one.
Fix a running toilet
Faulty flapper sealing. After a flush, the flapper does not seat correctly or completely allowing water to run into the bowl.
Jun 08, 2014 | Home
Water running into the bowl after flush and refil
IT SEEMS TO ME THAT THE BALL-**** (FLOAT SWITCH) IN THE CISTERN IS SET TOO HIGH UP. THERE ARE MANY DIFFERENT MODELS BUT ALL SHOULD BE EASILY ADJUSTED. HAVE A LOOK INSIDE THE CISTERN AND ADJUST THE FLOAT SO THAT THE WATER STOPS AT A LOWER LEVEL. IF THE WATER IS CONTINUOSLY FLOWING INTO THE CISTERN WHEN FULL YOU MIGHT NEED A NEW INLET WASHER
Feb 08, 2012 | Saniflo & Saniplus& Macerator Pump
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
8950 - Metro Urban Toilet - Two-Piece Toilets: water doesen't stop running...
Either the Fluid-master valve is going bad or your flapper needs to be replaced. Both are an easy fix. To check the flapper run your fingers along the underside of it, if the rubber comes off on your fingers its bad. Otherwise you'll have to try replacing your Fluid-master valve.
May 16, 2010 | Neo Metro 8950 - Metro Urban Toilet -...
Saniflo humming
hi ive had the same problem my problem was a blockage you will have to disconect the pump to clear it make sure u have a container handy to catch the water remember never put paper down it this will cause the problem hope this helps pete
Mar 06, 2010 | Plumbing
Hi i have a saniplus macerator unit hums but
sounds like an obstructed unit - you would need to remove the impeller cover at the base to check the pump - i'm assuming youve already checked the blade unit at the top (be careful here - i use a screwdriver - not my finger) could be that a simple cleanup and acid descale would be all thats needed. try this first then start looking deeper.Humming indicates motor is ok - but dont let it run continuosly - you dont want to burn out a good motor.
Dec 05, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
"Refrigerator/freezer runs continuosly but temp never goes below 42 deg in refrig or 18 deg in freeze"
well i hate to be the one to give you the bad news but most likely a bad thing... your compressor is 1. either weak, or 2 you are running low on freon....
Apr 27, 2009 | Refrigerators
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Home Logo
90 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
