Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool wfw9250wr00 ccu replacement
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: can you tell me what the error code E1 F9 means
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Thanks for using FixYa!!
Posted on Dec 24, 2010
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Mar 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load washer lost power at the end of a load
If you are not getting anything on the display, then the CCU has gone out and will need to be replaced. Here is the part to order.To access the CCU, remove the screws on the top panel, slide the panel back about a 1/4 inch and lift off. The CCU is located at the front right hand side. Take not of the wire connections. Be sure the unit is unplugged before replacing the CCU.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Code error F 01
EEPROM ERROR
A communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred.
PUMP DRIVE ERROR
The pump driver fails to activate.
MAIN RELAYS ERROR
One of the main relays is not working properly.
A power glitch may cause this error.
Unplug washer or disconnect power for two minutes.
Verify CCU operation by running a Diagnostic Test or any cycle.
Replace CCU board.
The relay might be soldered or always open.
Replace CCU board.
May 23, 2012 | Whirlpool Washing Machines
F-01 code on a whirlpool front load washer
Frontload failure code
F-1 EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error still exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU.
Sep 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet with a code F 11. I replaced the CCU, do you think its the Motor Control Board or is it time to recycle?
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). As you have already replaced the CCU then to start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After pressing the pause button on my Whirlpool duet washer I got an F01 error code. From checking around online, it seems that this happens to alot of people when they use the pause button. Would this be...
Error code F01 =EEPROM ERROR
PUMP DRIVE ERROR
MAIN RELAYS ERROR
Replace CCU board.
Replace CCU board.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I HAVE A WHIRLPOOL DUET
this is a communication error on the ccu board replace the ccu board
Mar 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader door locked
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
Sep 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
