Question about Kenmore 62972 Electric Dryer
Dryer not working
The dryer turns on, feel heat, but after a couple minutes, it trips the breaker.
  • 883 Answers
If, after a cool-down period, it can be re-started with same problem as stated, then the heating coil is in error. remove back panel and locate the heating element. Look for all electrical insulators to be not cracked and look for heating coil to be not stretched out or bulging and close to any other metal object. The coil can be fixed by pulling taut where it bulges and re-connecting it to itself so as to form a shorter length of coil. If insulators cracked, they must be replaced.
Posted on Jun 25, 2007
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
I have a double breaker switch for my dryer a few minutes after turning on the dryer the top switch trips the dryer will continue to run but not heat and it will not cut off by it,s self what is wrong?
if you reset the breakers, and just have no heat, but drum turns, the heat coil broke. if the double breaker only trips one side, the coil is touching the machine..
The breaker should have a little bar connecting both levers..if it does not have. go get one that does.
Dec 19, 2010 | Maytag PYE2300AY Electric Dryer
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Dryers
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Breaker trips but is ok now on low heat
First clean the vent in the machine and the wall. Try the machine one time not connected to the wall, see if it works better. Carefully tighten the wire connections at the breaker, including the white. It is possible for a breaker to get weak. Your motor may be wearing out.
May 11, 2009 | Dryers
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Kenmore 62972 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
