I am locked out of my epc wm8505 mini book, how do i get back in?
I did some research and there is no way to really bypass it I've tried those downloads that say it will clear the password but the computer will not boot/start up on a flash drive with the software on it and it looks like the only way is to factory reset it and if i do so then i have to re-download window ce 6.0
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Srartup Repair Not working?
Try:Turn the machine off, turn it back on and IMMEDIATELY press two keys: CTRL +F6. If you hear a distress series of beeps (around 5/sec) keep pressing for about 1 min. After that release F6 but keep pressing Ctrl for a while.At this point the MS Windows Boot Console should appear and offer you choices. Choose Boot in Safe Mode With Internet.
Now, that combination Ctrl+F6 is maker specific. It worked for my DELL
towers. Other manufacturers reportedly have other "secret" codes.
You may try Alt, Del, PgUp, PgDn instead of Ctrl. Also F6 is not cast in
concrete. You may try other function keys. Some machine may require only one key to be pressed.Every machine MUST have a code like this. It took me about 10 min to find.1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.2. Do one of the following:• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)4. Select a keyboard layout, and then click next.5. Select a user name and enter the password, and then click OK.6. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
Posted on Apr 19, 2012
SOURCE: windows boot failure. press ok to fix boot failure
Pressing [Alt]-[F10] during the boot-up is what your laptop uses to get to the Acer eRecovery Management Utility
However this may not be necessary, although it COULD be a virus, it also could simply be that the boot sector of the hard drive is corrupted/damaged, which can with some OS's be easily fixed, other's, not-so-easy....but still doable.
You've GOT to remember to let people know what Operating System you have to better advise you.
Posted on Sep 01, 2012
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
I can't remember the password for my laptop (Compaq Presario CQ60)
if you have another pc or can use a friends you can download "Hirens Boot CD" it's free and you just need to burn it to a disk and boot from it. Once it boots up it has a lot of tools including one you can remove the password. If you need help using it you can google it there is plenty of information.
Nov 26, 2012 | Compaq Presario Notebook
Wotcha, i've just taken amp out of storage, has'nt been used for a while cant get volume to work properly the sound goes from speaker to speaker and up and down in volume whilst crackeling a lot as...
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
http://www.overload.it/supporto/643/manuali/NAD-C350.pdf
Oct 15, 2011 | NAD C350 2-Channel Amplifier
I've had my external hard drive My Book Essential for a while now and had no problems with it until now. I would usually plug it in and the pop up screens would ask what you would like to do like...
The fact that it displays a '0% used' indicator probably means that somehow the data that you have hitherto stored on your external hard drive has been erased. This might not necessarily be the case, so don't panic yet.
The first thing I would try doing is reinstalling any software that came with your WD My Book. Not many external HDDs require additional software to run properly, but if yours does, then I strongly recommend reinstalling that first. I would then try using Windows Disk Manager to see if your computer is recognizing the G: drive as a hard drive, because I have had to use disk manager when I've added additional internal hard drives to my computer. If neither of these work [or you could not find the CD your My Book came with] I would search around online for driver or software updates available for your device.
One thing that I noticed while typing my suggestion for you is that before you attempting using the back up feature on your My Book, the drive for the My Book was (G:) but after you attempted the back up process the drive is indicated as (H:). I think that what might have happened was that when you attempted backing up the My Book, it was partitioned into a storage section (G:) and a section in which the backup data is stored (H:). If you can find and access it, the (G:) drive is likely to still contain all the data that you previously assigned to it.
If this doesn't help, I apologize, but I sincerely hope that your problem will be resolved.
Aug 24, 2011 | Western Digital My Book Essential 1TB...
I have a EPC notebook computer Model #MA200 I
Hi
please try pressing the FN+F5 keys together to see if this enables the keyboard
many thanks
Jul 19, 2011 | ASUS Eee 1000HA (EPC1000HAWHI001X) PC...
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
My epc minibook will not open up the inernet explore. Can u help me?
I have a Mini book EPC with wifi, 128m ram, and 2g flash card. The battery will only charge to 40% and that results in 15 -20 min of actual use. What can I do? Is there a replacement battery for these computers?
Dec 18, 2010 | Computers & Internet
Hi i have a new EPC mini laptop note book
I have a way to repair your laptop. I had the same problem you had and I was able to locate the files to repair it. Please contact me at blkfembrit@gmail.com for more information.
Dec 25, 2009 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
