Question about NetGear WGR614 Wireless Router
Can a netgearWGR614v9 router be configured as a bridge ?
    Novelist:
    Scholar:
  • 192 Answers
Yes don't use the WAN port only the 4LAN ports. set its IP to a unused IP in range of your 1st router (so you can still manage itand there are no IP conflicts). and MAKE sure to turn off DHCP. now its just a switch that works as a 2nd wireless access point.
I have 3 routers bridged together in my condo. works great going on 3 years.
Posted on Nov 21, 2013
Can a netgearwgr614v9 be configured as a bridge ?
Jan 01, 2013 | NetGear Computers & Internet
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
I am trying to bridge a belkin n router to a d-link router
ok
the simplest way is to find some alternatives, here as some suggestions
now if you do want to attempt your solution do a few things first
first you do need to go into the belkin router's configuration page you can do this by:
  1. Open a web browser on the computer.
  2. In the address bar of the web browser, type http://192.168.2.1
  3. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
or if you set up a password can't remember it do this first
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/F5D8231-4/p/312/r_id/166
now.. you need to find out if both routers support bridging.. you need to look into both router's configuration page, I couldnt find you router's manual and you did not posted you dlink router's configuration.
if you do find bridging try the directions found here
post back if you have questions after reviewing each router's configuration.
now an alternative option is to
Dec 27, 2009 | Belkin (F5D8231-4) Wireless Router...
Bought a Belkin router model # f5d8326 4 v2 was told this worked for cable modems not working yet
Make sure the modem is configured properly so it would detect the router. Most of the time, modems now has DCHP capability, meaning it has the ability to hold the username and password you ISP has provided you. The most effective way of making modems work with routers is to bridge the modem first before connecting the router.
Bridging the modem is done by opening the interface of the modem. To pull up the interface of the modem, type the default gateway of the modem in the address bar of your browser(intenet explorer)
Look for the "connection configuration" button and choose "bridge ethernet" as the connection type.
Once the modem is bridged, connect the router to the modem, then configure the router to set the connection type to pppoe. Once done, type your username and pw your ISP have provided the save the settings. This should cpnnect you online..
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
Wireless bridging
read ur user guide carefully in it it will give u ip addres with that it open in web browser then u can configured it .............
Jan 26, 2009 | D-Link AirPlus DI-524 Wireless Router
No connectivity to internet
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 26, 2008 | D-Link GamerLounge DGL-4300 Router...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Slow Internet
upgraded the latest firmware in the router, reset your router and reconfigure it, check if your dsl modem is configured in a bridge mode if not configure your modem in bridge mode and reconfig your links router accordingly, that will fix your problem
Nov 26, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
119 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
