Question about NetGear Computers & Internet
Can a netgearwgr614v9 be configured as a bridge ?
    Novelist:
    Scholar:
  • 192 Answers
Yes don't use the WAN port only the 4LAN ports. set its IP to a unused IP in range of your 1st router (so you can still manage itand there are no IP conflicts). and MAKE sure to turn off DHCP. now its just a switch that works as a 2nd wireless access point.
I have 3 routers bridged together in my condo. works great going on 3 years.
Posted on Nov 21, 2013
Can a netgearWGR614v9 router be configured as a bridge ?
yes don't use the WAN port only the 4LAN ports. set its IP to a unused IP in range of your 1st router (so you can still manage itand there are no IP conflicts). and MAKE sure to turn off DHCP. now its just a switch that works as a 2nd wireless access point.
Jan 01, 2013 | NetGear WGR614 Wireless Router
Configure dpc3000 for bridge mode
GO WAN OPTION AND EDIT THIS OPTION AND SELECT BRIDGE OPTION AND TRY
May 31, 2012 | Cisco DOCSIS 3.0 DPC3000 Cable Modem...
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
How to configure it for point to point network
I'm assuming you have two of these.
Configure one as an access point. Choose a frequency channel, an SSID, a power setting, and an encryption method and password. Set its administrative password. Give it an IP address in the proper range of your LAN, and attach it to your LAN switch. Point it properly.
Configure the other as a bridge or a bridge-router, as you require. Tell it what SSID to find, set its power setting, and give it the same encryption method and password. Set its administrative password. Give it a different IP address in the proper range of your access point's LAN. If you configure it as a bridge-router, configure its own LAN side as you wish. Point it at the remote access point, and within about 30 seconds it should pick up on the signal and you will have a point-to-point network.
Sep 03, 2009 | EnGenius EOC-3220 EXT (EOC3220EXT)
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Aironet 350 series wireless bridge
If nothing else has changed with the configuration, then I suspect that you are experiencing high levels of interference. Try changing the channel on both bridges.
Apr 14, 2009 | Cisco Aironet 350 Series Wireless...
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
How to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
How to Use as Simple Bridge
set the uptime variable to "0" in the main bios sytem configuration 7
Nov 11, 2006 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Computers & Internet Logo
26 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
