Question about BenQ MX503 DLP Projector
Vertical lines on mx503 projector
Vertical lines on screeen projected
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
Can I project vertically by changing projector orientation?
I have checked over the specs on a few different sites and ive found where a few people have stated that theyve used theirs in vertical position with no problems. If you are that worried you should be able to go to whatever program you are using and rotate the picture there also.
Sep 17, 2007 | NEC LT 240K Multimedia Projector
I am getting a vertical white line that runs from the top of the screeen down to the bottom of the screen. It is about 2" wide on a screen 12' away. It flickers. It rotates to the other side of the...
it is most likely the dmd board on the light engine. very expensive and parts may be hard to find for a projector that age. you could try to find a 4800 on ebay for parts....
Feb 03, 2011 | InFocus ScreenPlay 4800 Multimedia...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Green vertical lines
reset the settings to factory default. the resolution doesn't match.
Nov 20, 2008 | Office Equipment & Supplies
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
BenQ MX503 DLP Projector Logo
46 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
