Nissan VQ25 has engine light and diagnosis indicated solenoid valve. Where is this valve located and how does it function?
Plugs replaced and nothing changed.
  • 7,627 Answers
Wrong category
Posted on Jan 02, 2013
Sound like engine have a misfire what all i need to check?
Error Code P1800 is defined as Variable Intake Air System Control Solenoid Valve Circui replaced the solenoid
Jan 16, 2018 | Nissan Cars & Trucks
Two codes coming up on car even after fixing alot on car now need to figure out low cost ways to fix P0744 & P0722 code issues spent 1,800 on car & have spent 1,400 already in parts & labor.
you need a better mechanic that traces ALL of the possibilities of each code, not just read the code and trow in a part hoping that it's fixed ~ it can be wiring as well, not just plug in a new part as mentioned on the 2nd trouble code to the vehicle speed sensor
P0744 Torque Converter Clutch Circuit Intermittent
P0722 Output Speed Sensor No Signal
the first of the 2 looks to be more intensive to trace and find out the problem & the 0722 is the easier job for an intermediate mechanic to trace the wiring for continuity
Apr 20, 2015 | Cars & Trucks
I got a OBD car fault code po745.,on my Renault methane senic 2003., 106k ml.,what does it means?
P0745 - Pressure Control Solenoid Malfunction Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty line pressure solenoid valve
- Line pressure solenoid valve harness is open or shorted
- Line pressure solenoid valve circuit poor electrical connection Help with this
Tech notes
When the a transmission solenoid is malfunction, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
Help with this
When is the code detected?
The P0745 is detected when TCM detects an improper voltage drop when it tries to operate the solenoid valve.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission shift shock
P0745 Description
The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM).
TURBO BOOST PRESSURE SOLENOID VALVE DIESEL VAUXHALL MOVANO VIVARO RENAULT...
Apr 11, 2015 | Renault Megane Cars & Trucks
Clio auto gear selector the A keeps turning off
possible causes
- low transmission fluid level
- dirty transmission fluid
- faulty line pressure solenoid valve
- line pressure solenoid valve harness is open or shorted
- line pressure solenoid valve circuit poor electrical connection
when the a transmission solenoid is stuck off, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. if the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
read more: http://engine-codes.com/p0746.html#ixzz3ptojq4bp
Jan 21, 2015 | Cars & Trucks
1998 toyota ob755 seems to shift ok but keeos calling out 755 cntl v B
- Faulty shift solenoid B valve
- Shift solenoid B valve harness or connectors
- Shift solenoid B valve circuit is open or shorted
these are couple causes to turn on your check engine light
If you need further help, reach me via phone at https://www.6ya.com/expert/bryan_972744e20e2f7260
Jul 12, 2012 | 1998 Toyota Camry
Po756 code and blincking od light 96 ford explore
P0756 FORD - Shift Solenoid 2 Performancexicon.jpghttp://engine-codes.com/p0756_ford.htmlForum CodePossible causes- Low transmission fluid level
- Faulty shift solenoid 2 valve
- Shift solenoid 2 valve harness or connectors
- Shift solenoid 2 valve circuit is open or shorted
help.png Help with thisTech notes When the a transmission solenoid is stuck off, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
Jul 06, 2012 | 1996 Ford Explorer
I have code PO744
likely causes-
Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
Tech notes When the a transmission solenoid is working intermittent, in most cases the problem is not the electrical part of the solenoid; the problem is foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis. Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
Jan 11, 2011 | 2000 Kia Sephia
97 Nissan Maxima OBDll code p1400. I replaced the egr valve the code still flips any suggestions would be greatly appreciated
The code p1400, is for an egrc solenoid valve, not the egr valve, they are 2 seperate items
exhaust-gas recirculation (EGR): An emissions-control system that reduces an engine's production of oxides of nitrogen by diluting the air/fuel mixture with exhaust gas so that peak combustion temperatures in the cylinders are lowered.
exhaust-gas recirculation valve (EGR valve): A valve, generally vacuum operated, to regulate the exhaust gas flow into the intake manifold.
EGR control solenoid (EGRC): receives ported and manifold vacuum, an EGR temperature sensor and a control backpressure transducer valve. THE operation of the system is controlled by the PCM which operates the EGRC solenoid. The manifold vacuum system utilizes a vacuum tap in the air intake system positioned after the throttle valve. The ported vacuum control system uses a vacuum tap in the throttle body which is exposed to an increasing percentage of manifold vacuum as the throttle valve is opened during acceleration. The backpressure transducer valve monitors the exhaust backpressure as the engine rpm increases or decreases to aid in controlling the amount of the EGR vacuum signal. The EGR temperature sensor is used to inform the PCM of temperature changes in the EGR passage way. This helps the PCM determine the EGR on/off time.
that should help on what they all do.
now by knowing all of that i highly doubt that the control solenoid could cause the problem, and if it was that then u probably have a PCM problem not the solenoid or both.P01400 generally means that the ECM is not seeing the correct voltage drop when it grounds the EGRC valve located between the banks of CLY'S near the top Radiator hose location the EGRC solenoid valve turns vacuum on to the EGR circuit or vents. With a OHM meter unplug the EGRC valve and measure resistance at the two pins. Most likely your car has a bad EGRC valve or a BAD wire to it from the engine control module. Valve Nissan Dealership would cost around $45 labor to diagnosis and replace $150. Make sure proper diagnosis is performed check the engine wiring harness with a stop lamp light bulb hooked to the EGRC connector to see if it lights up when driving. That way you know the circuit is ok. A engine harness with a open circuit is a bad surprise after spending $200 for the valve. Good Luck
Oct 08, 2010 | 1997 Nissan Maxima
Hi i have 02 altima 3.5 v6 who have check engine light with code p1800 what is manufactured transmission control can anyone help me what that means?
You may want to have someone else take a look at it. The Nissan P1800 trouble code is not a transmission control problem. It is described as follows:
Trouble diagnosis name: VIAS control solenoid valve circuit.
Component Description:
The VIAS control solenoid valve cuts the intake manifold vacuum signal for power valve control. It responds to ON/OFF signals from the ECM. When the solenoid is off, the vacuum signal from the intake manifold is cut. When the ECM sends an ON signal the coil pulls the plunger downward and feeds the vacuum signal to the power valve actuator.
DTC detecting condition:
•An excessively low or high voltage signal is sent to ECM through the valve.
Possible cause:
•Harness or connectors (The solenoid valve circuit is open or shorted.)
•VIAS control solenoid valve
Check your vacuum hoses to make sure they are in good shape and are securely attached Aslo check the wiring harness is ok and securely attached as well. If they are, you’ll probably need to replace your VIAS. It's right next to the throttle body.
Jan 25, 2010 | 2002 Nissan Altima
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
