Question about Comfort Zone Infrared Quartz Heater
My Cz2011 Comfort Zone Infrared heater will not stay on. It will stay on for maybe one minute and then it shuts off
Will not stay on
    New Friend:
IF IT WAS LIKE MINE , IT WAS THE P.O.S. THERMO SWITCH. SOME WHERE THERE IS INFO FOR A REPLACEMENT PART AVAILABLE TO REPLACE THIS JUNK SWITCH, I GOT MINE FROM AMAZON. THE OLD SWITCH IS A BLACK SEMI -ROUND UNIT THAT IS BEHIND THE BACK COVER. THE BAD SWITCH IS A WEAK LINK TO THIS UNIT. ITS HELD IN PLACE BY A SCREW ON THE BOTTOM OF THE THERMOSWITCH. JUST REPLACE THE WHOLE DEFECTIVE SWITCH, I DID IT TO MINE AND NOW THE THING WORKS WELL. JUST UNSCREW,UNPLUG, AND ISTALL THE NEW THERMO SWITCH. GOOD LUCK....PS...MAKE SURE THE UNIT IS UNPLUGD!
Posted on Nov 11, 2014
  • Joanne
    Joanne Nov 25, 2014
    Can you post the part number you bought? Thanks
I had same problem with mine and found out that the timer was turned on make sure your timer time is set to 00 hope this helps
Posted on Nov 29, 2013
  • 7 Answers
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Posted on Oct 02, 2010
emissionwiz
  • 80668 Answers
SOURCE: I have an AO5 error
what is A05
Posted on Sep 10, 2010
  • 383 Answers
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Posted on Jan 15, 2011
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
SOURCE: My comfort zone infrared hearter
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Posted on Nov 24, 2010
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
Oct 15, 2016 | Comfort Zone CZ1500WC Infra-Red...
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Comfort Zone Infrared Quartz Heater is not staying on it cut right off. Please advise
Clean the filter and the element. Make sure that they are dry before you re-install them. Check the power cord and socket for damage..
Feb 21, 2015 | Comfort Zone Heating & Cooling
Comfort zone cz2011 fan very nosiey
It is under warranty, is it not. check it out. or create merry hell with the installer.
Jan 11, 2014 | Comfort Zone Heating & Cooling
Why does my comfort zone infrared heater shut off after I turn it on? What modes does it have?
What is wrong with my Comfort Furnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Oct 08, 2012 | Comfort Zone CZ1500WC Infra-Red...
Comfort zone cz2011 why will it not stay running
I had the same problem. It would cut off after approx 30 sec to 1 min. If the power shuts off or screen and lights go off most likely the problem is the thermal cutoff switch comonly called a thermostat. (Be Sure you are getting good air flow also check filter JIC) I found the problem but the parts in the systema are cheap off brand parts. Low quality circuit boards and soldering. The PN on the switch was unknown. Since I didnt know the cutoff temp I called the mfg which did not offer any parts, prints etc. This is an expensive throw away heater is basically the answer I recieved. My unit also had very low use as it is used as a supplimental heat ocassionally. Instead of tossing the unit I looked a little closer at the switch. I found 120 deg C stamped on one of the .25 QC terminals. On the front it is stamped 120/240V 16A. After a search I found the SRL250. It is a 250 deg F 15A 120/240VAC. (120 deg C = 248 deg F). It is 1 amp less which is fine as the 1500W unit should not draw 15 or 16 Amp. I now have the heater running again. You can find this part online or you local appliance parts house should have it. Or Cross ref to another mfg. Hope this helps.
Orig- 120/240VAC 16A 120 deg C (Open on Rise)
New - 120/240VAC 15A 250 deg F (Open on Rise)
Part# - SRL250
Feb 20, 2012 | Comfort Zone Heating & Cooling
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Oct 03, 2008 | Comfort Zone Heating & Cooling
Comfort Zone Infrared Quartz Heater Logo
1,491 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
