Question about Garden
My snowblower is MasterCraft 8-26, Briggs & Stratton 4 cycle engine Model # 319825515, 8 Horsepower I think. I need to know how to access the drive belt.
It does not go forward or backward. It was working excellent and just lost its forward and backward drive. it is old around 1980ish.
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
panilling9
  • 284 Answers
SOURCE: Need engine HP
10 hp
made in the early 80`s
Posted on May 26, 2009
  • 376 Answers
SOURCE: Ichanged the rear drive belt on my 17 hp
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Posted on Jun 22, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
  • 302 Answers
SOURCE: I need to know the valve setting for a Briggs
Around .08-.10 clearance at top dead center.
Posted on Jun 30, 2010
I need a manual for a mastercraft 12 horsepower snowblower 30 in cut
Try Googling (Mastercraft)(model)(manual) without parens.
Jan 11, 2018 | Mastercraft Garden
Wadingriver, 536.881800 Craftsman. Don't see a fill plug. See it on the diagram, but not on the differential ....
Questions, Troubleshooting Help & Support Page 7 - Fixya
www.fixya.com/troubleshoot/page-7
wadingriver...it's 536.881800 craftsman snow blower...2004 Shows a fill plug on diagram but don't see any plug on the differential ยท Snow Blowers ' Answered 1 ...
Don't buy a Craftsman snowblower with a Briggs & Stratton ...
? 2:50
https://www.youtube.com/watch?v=cBfglXb9hx4
Aug 15, 2011 - Uploaded by dannylafrance19
Don't buy a Craftsman snowblower with a Briggs & Stratton motor .... These should be a metal plug (like the drain plug) on these models that do not ... With the vibration of these engines,one cansee how these may eventually ..
Nov 24, 2015 | Cars & Trucks
I have a 3.5 horsepower B&S push lawn mower. It is easy enough to start, but once started it fluctuates. Runs high and then low almost as if it will cut off and then it runs high again. What can I...
I have a Briggs & Stratton 3.5HP Model 91212 type 1319E1 engine that I'm having trouble keeping running. Once it starts it will run about ten minutes, then die, and then is impossible to get re-started. Is this a carburetor problem, or possibly a coil?
Kent
Aug 31, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
My Lawn mower seems to be produced by ALKO, but has the Briggs and Stratton emblem also. It is the 40b model and having just inherited it, I am trying to find out if I put just petrol in or whether I need...
Hi scottcoles5...
The easy way to find out if the motor is 2 or 4 cycle is to check to see if the engine has oil in the crankcase...if it does it is a 4 cycle and you will NOT have to mix oil with your gas. 2 cycle engines do NOT have an oil in the crancase and depend on the oil you mix with your gasoline.
You can also check the color of the gasoline in the tank, most 2 cycle oils contain a colorant to color the gas to let you know there is oil in the gas...
Free Answer...Please take time to rate me
May 31, 2011 | Briggs & Stratton Briggs Stratton...
Want to repower an ariens model 10M6d snowblower engine. Is there a replacement engine I can use?
Go to small engine warehouse. There is an button on the top, repower old equipment. They have a few briggs & stratton engine options there.
Jan 17, 2011 | Ariens Garden
357cc is equal to what in horsepower MTD
From my website: movingsnow.com. Five years ago the power output of every snowblower sold here in the United States was measured in hp or horsepower. It was a nice simple measurement that everyone was used to.
Three years ago they changed the rules and started selling snowthrowers with the power measured in gross torque. Of course no one understood what this meant and even though companies like Briggs & Stratton tried to explain it, it still didn't make much sense.
Well they changed the rules on us again.
So we just start to get used to measuring an engine's output in torque and now for the 2009/2010 season a lot of the snow blower manufacturers are dropping the torque measurement and only giving us engine size in cc's.
I spent a great deal of time researching this and I'm not going to spend time trying to explain why the engine manufactures have changed their terminology. Instead I'm just going to show you a formula you can use to figure it out yourself.
Here's the formula I used from the Briggs & Stratton website (rpm x torque / 5,252) The engine manufacturer's used 3600 rpm most of the time to rate the engine's horsepower so I will use that number in the formula. I also used the torque ratings from the Briggs & Stratton website for their motors to keep this chart simple. Other manufactures (like Powermore) may have different torque ratings for their motors. If you are trying to get exact hp measurements you should research the torque ratings for the specific brand.
For 2009/2010 MTD has dropped all torque ratings on snow throwers. The engines are only labeled in cc's.
Here is a simple chart of approximate cc to torque to horsepower conversions. It's not exact, but it will give you a better idea of how big the new engines are. I used 3600 rpm in the formula for this comparison. Assume that your new snowblower motoe runs at less rpm.
123 cc = 4 hp
179 cc = 5 hp
208 cc = 8 to 9 Gross Torque = 5.5 to 6 hp
277 cc = 11 to 11.5 Gross Torque = 7 to 8 hp
305 cc = 13.5 to 14.5 Gross Torque = 9 to 10 hp
342 cc = 15.5 to 16.5 Gross Torque = 11 to 12 hp
357 cc = 12-14?
420 cc = 14-15?
To me cc's is not a good comparison from one motor to another. It is also not a good comparison from one manufacture to another. For example, a 190cc Briggs & Stratton side valve motor will not have the same power as a Honda 190cc overhead valve motor. cc'c doesn't give you a good measurement of what the engine is capable of. True, an overhead valve motor from a specific manufacture should have more power with more cc's but there are a lot of other factors that go into determining how much power is available for you to use. The true power of a motor is determined by engine type, (overhead valve/side valve) carburetor (naturally aspirated/fuel injected/turbo) rpm you use it at (2750/3100/3650) and many other factors. I hope this helps.
Jan 03, 2011 | Garden
How do you time a 20 horsepower intex engine
i believe the ignition timing is not adjustable , if you think you might have a timing issue you need to chech if flywheel keyway is twisted or sheared
Mar 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Electric starter won't work on snowblower, replaced it once
If this is a briggs & Stratton engine no the starters are easy to get and replace usually just 2 bolts hold them in. Depending on how long ago you replaced the last one I would check out the system for problems before I installed a new one as starters usually last for yrs. Things that would ruin a starter are excessive heat or power staying on the starter after startup as this would cause excessive wear. Hope This Helps Don
Dec 08, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
