Question about CyberLink PowerProducer 2 for PC
Burning dvds I encountered an error when trying to burn a dvd. I went through all the steps for the power director and power producer and when I got to the DVD burn part, I got an error message that said Burn failed because the "pins" aren't compatible. What does that mean and why can't I burn a dvd? very frustrating
  • Pat Shine Dec 13, 2007
    Yes same problem - when I try to burn the message pops up "There is no common media between these pins"
  • 32 Answers
You are probably missing the correct codecs for what you are trying to do. easiest solution is to donwload something like ace mega codec pack. http://www.free-codecs.com/download/ACE_Mega_CoDecS_Pack.htm install and try again
Posted on Jun 25, 2007
SOURCE:
Cyberlink Power Director 14. Burning Unsuccessful. Error eFF030C00
DVD-R disc probably defective. Source for another make of DVD-R disc and try again.
DVD capacity matters; how many Gigabytes of data can it take/record/accommodate
4Gb
8Gb
Oct 13, 2017 | CyberLink Computers & Internet
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
Problems burning dvds, any software, same error
First, stick with DVD's that have worked in the past; Verbatim is the best.
Perhaps the laser needs cleaning. If you have a can of compressed air, open the DVD tray and shoot a few seconds of air in the DVD drive, being careful not to tilt the can. Do not shake the canned air bedore using.
If there is still a problem, use a laser lens cleaner ($13 Radio Shack). It is an audio CD with a row of brushes on it. Turn on your speakers / headphones and follow the instructions. No chemicals involved.
Sep 29, 2009 | Computers & Internet
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
May 28, 2009 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
Why would my dvd writer start finalizing?
Try a Better Brand of DVDs. Cheap DVDs sometimes doesn't burn correctly. Get a DVD cleaner and clean your DVD player.
Jan 08, 2009 | Microsoft Windows XP Professional for PC
Burning video files to DVD - Won't play on TV
What software are you using to render and burn your DVDs ?
Mar 19, 2017 | JVC GZ-MG730 HDD Camcorder
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
Nov 19, 2007 | Acer Aspire 3680 Laptop
CyberLink PowerProducer 2 for PC Logo
283 people viewed this question
Top CyberLink Computers & Internet Experts
Alli Abiola
Alli Abiola
Peter Dragonetti
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
