Question about Frigidaire ATF6000ES Front Load Washer
Fafs4474lwo washer is stuck on the pause feature
  • Official Brand Answer
  • 4,342 Answers
Hello Claudia Clary - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective then the unit may be experiencing a communication issue with the control board, faulty keypad or wiring failure. Contact a professional to move forward accurately.
Posted on Jan 06, 2013
Why is control stuck on pause?
Thank you for allowing me to assist you, Friend.
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps! - Z
Aug 17, 2014 | Frigidaire Washing Machines
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Eifls60jiw washer goes right to pause
You probably have a stuck button on the touch pad. Try pressing it repeatedly firmly it may unstick.Otherwise you may need to call a pro to diagnose the problem.
Nov 17, 2013 | Electrolux EIFLS60JIW Front Load Washer...
Cant get it off of the pause feature
press pause button again, wait for it to respond
(make sure door is closed)
if that doesn't work, press and hold pause button until something happens.
if that doesn't work, power off, then restart
if pause is on all the time, and never resets, even after power down/up your button is stuck/broken, fix/replace button or panel.
Jan 01, 2013 | Washing Machines
The start / pause button will not work ...all other buttons are working
Make sure that the front door is locked or that the door switch is contacting to give the feedback signal to the main circuit board. This is a safety feature of the washer because unless the front switch works - door shut-the washer will not work - no action on start/pause.
Replace if the switch is faulty.
Feb 07, 2011 | Zanussi FLE1416W Front Load Washer
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
until the control is unlocked.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
