Question about Electronics - Others
How can i remove kvusb security from my epro 4gb flashdisk
  • 27,725 Answers
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driver Click start click on my computer you should see your usb drive right click then select format. another way is to control panel administrive tools computer management disk management right Click on your drive select format
hope this helps
Posted on Jan 11, 2013
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
Jan 17, 2014 | Korg Pa50 Professional Arranger Keyboard...
My 4GB USB was reduced into 0.97 MB how can i repair and bring it back to 4GB?
This problem could be usb chipset if you can't restore by the following solution. 1. Try Partitioning the usb flashdrive thru disk management.Right click my computer>manage>disk management. See if the disk is recognizable.Try to repartition / Format 2. Use third party program like HP USB disk storage format tool/PTDD Super Fdisk/ repair flashdisk. 3.Partition magic 8.0 is very useful in terms of sizing of drive, try playing this tool. 4. Go to the site of your brand usb drive sometimes they have their own recovery tools or low level formatting software that might help you!Thanks.
Sep 21, 2011 | Computers & Internet
What is the default password for secure lock toshiba usb flashdisk 4GB??
I am not 100% sure but I do not believe it has a Default Password I think they come blank and passwords are set only if you want it set.
Thumbs up if helpful!!! Good Luck!
Jun 13, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
My flashdisk can't be formated why.? i don't know how to solve this problem what i can do.
Any disk can be formatted if you have the appropriate software.
The SanDisk Cruzer Micro comes with a security software that the owner can enable. If it is enabled, you cannot open it under Windows unless you enter the correct password . Also, if the security is enabled, you cannot even open it under Linux or Mac OS. An if you cannot open it you cannot format it. I do not know if that answers your question or if that is the real reason you cannot format it. That is one possibility.
Jun 07, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My pendrive file system change to raw & I don't want to format it because have very2 important data inside.
Hi, welcome to FixYa.
This sometime can be happened if you remove your flashdisk without safely remove it first from Windows. You can still recover the files inside your flashdisk. There's a lot program can do that, but I usually use Partition Find and Mount.
Download it from here:
http://findandmount.com/fnmsetup.exe
The instruction are here:
http://findandmount.com/howtouse/
I hope this can help you.
Mar 11, 2011 | Computers & Internet
When i use my epro live drums on live gigs i sometimes get no sound when i hit the pads specialy the snare pad
Not used this kit inparticular, but if there is a main "brain" or sound mudule, check sensitivity settings. If not, take the pad to the store where you got it as the internal sensor may have gone, or the link lead may be faulty.
Jan 16, 2011 | Pearl ePro Live EPLX205P/C31 Electronic...
What is mean when you open your usb flashdisk and said that insert disk to any drive like drive e
when you insert your usb stick into the usb click on my computer and it will be listed theyre it will say removable disk A,F,G, etc. that is what is meant i hope this helped.
Jul 12, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sandisk Cruzer Professional 4GB usb flash drive issue
If you pull out the flash disk while it's working, you can damage its bootrecord. In this case Windows tells you that flash drive is not formatted because cannot read the from master boot record or FAT (file allocation table)
You can scan your flash drive attempting to repair boot record or use a flashdisk recovery tool if you have importanta data in it.
If not you can format your flash drive.
Jul 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
60 people viewed this question
Top Electronics - Others Experts
Sunday Ojelabi
Sunday Ojelabi
ka4iup
ka4iup
 Roderiq Jay
Roderiq Jay
Level 1 Expert
Are you an Electronics - Other Expert? Answer questions, earn points and help others
