Question about RCA HD52W59 HDTV Projection Television
I need another cable connector.
I have taken the body off the the back of the tv and notice that there are two silver boxes that is use for the cable connector. How do I take the two silver boxe out of my televison?
    Genius:
  • 1,030 Answers
These silver boxes are the tuners for the televsion. at the shop to remove these you have to remove the curcit board these are on. Once you get the board out. the tuner can be removed by unsoldering them. Depenending on the damage to te tuner it may be possible to replace the connector. I like to atleast try. You can also replace the tuner slightly more expensive but essear to do
Posted on Jan 18, 2009
Why is my sony bravia not tuning in and can you tell me how to fix it
The TV is probably not seeing the signal. Are the cords connected in the right slots on the cable box and TV (cable TV wire into the cable input connector on box, and cable out to the TV in the cable out connector on the box, and then connected to the right connector on the back of the TV)? Or, maybe you may need to go into the TV screen options and choose the the right external source that will allow the TV to see the signal.
Sep 18, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I got a memory card card reader that fits in myu tower it conects to the front usb pins but i dont know which way around the connector needs to be
David, first take a look at the connector at the end of the card reader's cable. It should be a rather wide rectangle, silver in color. You'll notice that one of the two wide sides has a thin line in the metal (or a ****, or whatever one might call it). That side should generally face down when you connect the cable to your PC.
If the USB connections are on the back of your PC and are vertically oriented, it's slightly trickier. You'll probably notice that the USB "ports", as well as all the other cable connections, are all grouped together in a rectangular area, with many of the connections being colored. That rectangular area is probably flush with one or the other side of the tower. While looking at the back side of the tower, the side that rectangular connector area is closer to is considered the "bottom direction". So if it were, say, on the left side, turn the USB connection so that the side with the **** is on the left as you connect it to the PC.
If you're unlucky enough to have a USB connector at the end of the cable on which both of the wider sides look 100% identical (without that distinguishing ****), then another way to figure it out is to look into the inside of the connector. You'll notice that it's partly hollow, and the other half is taken up by a white, black or possibly blue piece of plastic. Turn the connector so that that plastic part is in the lower half
Aug 08, 2011 | Computers & Internet
LG LED 42LE5300. We just bought this TV last week. When we first installed it, we noticed uniform horizontal tiny lines on the picture. We tried to change the cable box, use high res. HDMI, even tried...
Does any OTHER TV show the same problems when connected to that very same cable connector? It could be a bad connector, or a bad crimp on the connector! Did you try cleaning the center wire on the (disconnected) cable connector? I'm talking about the WIRE cable, not the TV connection!
Apr 29, 2017 | Televison & Video
When I turn on my LCD TL3220 the screen shows a 3" x 6" silver box that says "no sync detected". I have checked the cable box and that seems to be working. Any suggestions
The word ''no sync detected' means that there is no video connection between the cable box and the TV set. Isolate the source of trouble by connecting to the TV a prevoius video source that worked properly e.g DVD player. You should also try to get a new set of video cables as the ones you have may be internally broken.
Please follow the installation instructions carefully especially the colour codes of the video and audio cables i.e yellow cable to yellow connectors of TV and cable box , Red cable to red connectors of TV and cable box etc.
good luck!
Oct 09, 2010 | Hisense TL-3220 Television
I have a hatachi 60 rear projection tv, the cable port on the back of the tv is broken, i pulled the back off the tv and pulled off the silver box, the f-connector that goes to the incoming cable line, is...
This can be soldered back into the tuner if the board in the tuner is not broken. If you need a new connector any electronics supply store will carry it.
Apr 14, 2009 | Televison & Video
No signal
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
May 25, 2008 | Insignia Digital-to-Analog Converter for...
Broken Cable Jack on c27a24t
You should take this to a service shop to have it properly repaired. They may have to order a new tuner module if the circuit board inside has been damaged.
There are safety issues with grounding and AC mains isolation with this connector.
Servicing this can have serious safety issues. Take the set to a service center if you want it repaired.
For the average TV set, the tuner module is rather expensive. It can be in the area of about $70 to $120 depending on the model. There is about 1 hour of labour involved if there are no problems to change it.
You may be lucky, and the service tech may be able to fix the connector back to the tuner case or have a way to change it.
If the set is more than about 5 years old the tuner module may no longer be available.
Jerry G.
Apr 19, 2008 | Zenith C27A24T 27" TV
Rca d52w19byx1
You could get away with replacing it if you get a 'freeview box' and connect it to the scart socket on the back of the tv and then connect your ariel into the freeview box instead.
Nov 12, 2007 | RCA D52W19 52" Rear Projection Television
1996 32 inch Panasonic TV
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Jun 27, 2007 | Panasonic CT-32G23 32" TV
LCD screen nonresponsive
if your . . . remote . . . works ok ? your touchscreen internal connector could be loose disconnected - or defective ( not field repairable ) ;
Oct 20, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
RCA HD52W59 HDTV Projection Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
