Question about Goldstar MV-1615 Microwave Oven
Goldstar MV1611 has the letter L on screen and beeps
Control panel does not function
  • Tom Fornaciari Jan 04, 2013
    I unpluged the oven for about an hour and pluged it back in. The oven worked for a 1/2 hour and began to beep periodicaly with the letter L on the display and no display panel functioning. I then left it unpluged overnight and it has been working fine for three days now.
Goldstar MV-1526W Microwave Oven caught fire over the control panel. The fire was on the connection to the LG Magnetron 2M214 can it be fixed?
take it to a repair shop for a proper diagnosis but generally anything other than a fuse , it will be cheaper to get a new unit
Jan 02, 2017 | LG Microwave Ovens
Goldstar microwave GMV 1540TW locked
From the handy owner's manual here:
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
To cancel child lock:
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 06, 2011 | Goldstar MV-1526 Microwave Oven
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
I need to know how to unlock it
The Child Lock is on.
Your owner's manual covers it. If for some reason you don't have yours, you can download it free here.
CHILD LOCK
You may lock the control panel to prevent the microwave from being accidentally started or used by children.
Example: To set the child lock.
1. Touch STOP/CLEAR.
2. Touch and hold START more than 4 seconds. LOCKED will appear in the display window with two beeps.
Example: To cancel the child lock.
1. Touch and hold START more than 4 seconds. LOCKED will disappear and you hear two beeps. At this time the oven is ready.
Dec 13, 2009 | Goldstar MV-1501 Microwave Oven
My Goldstar 1500 Micro wave no power
HEating element popped and needs to be replaced. Also check for discoloring on the sides and back of the panel. This will also tell you what is going on. Make sure that the power cord did not break either and that it is fully attached where it is supposed to go
Jun 03, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar 1500m
The most common causes for this (in order) are a defective door switch, door switch mount, or a bad connection or relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
May 25, 2007 | Goldstar MV-1501 Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
Goldstar MV-1615 Microwave Oven Logo
51 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
