Question about Minolta Maxxum 7000 35mm SLR Camera
I cant get the film door open
Soooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
oooooooooooooooo
oooooooooooo
hjjjjjjjjjjjjjj
hhhhhhhhhhhhhhhhhhhhhhhh
hhhhhhhhhhhhhhh
hhhhhhhhhhhhhhhggggggggggg
fggggggggggg
hh
    Scholar:
  • 185 Answers
Navonod420,
there are no new parts for this model minolta, however you may be able to repair it.
at the back cover open button remove the leather and then the small screws that hold the button mechanism. lift off the cover ( careful of the spring ) try to bend the flat shaft enough so it grabs the release lever put the spring back, align the button and cover to the shaft. replace the screws and leather.
now if the plastic rivet holding the button to the cover is broken it's not repairable unless a good used part can be found.
Posted on Jan 22, 2009
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
The back of my camera is stuck closed and I cant get my film out. Several people have tried with no success. Can you tell me how to get it open without breaking the camera? Thank you!!!
I've seen this happen multiple times.. Sometimes taking the camera in and out of certain environments can cause the plastic to bend and expand. The way I've fixed this is to simply remove a couple screws from around the camera and the door holding the film in. Sometimes you have to remove all the screws.
Doing so will not damage the unit, just don't pry it apart. Unscrewing a couple of the small screws will loosen the grip that door has a little bit and you should be able to get it open.
Thanks!! Hope this helps! If it does, please rate :)
Mar 29, 2011 | Minolta Freedom Zoom 130 35mm Point and...
Ok i have a minolta x 370 and i have no clue how to open the film door. i cant find any button or anything???????confused!!!!!!!
Lift up on the film rewind know and the back will pop open.
You can download the manual at
http://ca.konicaminolta.com/support/manuals/film-cameras/film_mf_slr/x_7a/x_7a_manual.pdf
Jan 16, 2011 | Cameras
Cant open the film canister
Just lift up on the rewind knob to open the film ( back ) door.
Jan 20, 2010 | Vivitar V3800N 35mm SLR Camera
Canon elph 2 film door wont open , tried to open with door release button but wont budge.
You need the camera powered up and all the film used to activate the release mechanism for the lock to release the film door, the Elph film door will not open until all the pictures have been taken. It uses A CR2 Lithium battery
Sep 04, 2009 | Canon Photography
FILM DOOR WILL NOT OPEN on nikon f2
The F2 has a door knob on the bottom cover. Flip out the handle and rotate it counter clockwise to open.
Apr 07, 2009 | Nikon Photography
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Cant get the door to open to load my new film?
push in the black button on the bottom of the camera
Oct 26, 2007 | Nikon FM10 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
119 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
