Question about Maytag Washing Machines
How do you replace the lid hinge on maytag mvwb750wq1 washer
IFIXALL
  • 868 Answers
SOURCE: maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
Posted on May 23, 2008
rickzilla
  • 706 Answers
SOURCE: Replace top loader lid hinge Maytag PAV 3240
Hello scottwbecket,
Not sure I have the right model for you but try this link to see if it provides exploded views of your washer ( as well as parts and electrical diagrams) If it is correct, you should able to see how the top is assembled and simply remove it. If not,you can plug in your real model number at this website and it should provde those details for you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Nov 26, 2008
SOURCE: How to replace hinge lid pins
I had an apprentice reply online. Read answer posted Jan 25th and my comment Jan 27th. Thanks.
Posted on Jan 27, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
Cannot find where lid switch is located
It is normally at the back of the hinge of the lid. It is usually hidden in Maytag washers. Usually on the left side.
Jan 09, 2014 | Maytag LSE7806A Top Load Stacked...
Hi. How do you get to the lid switch on a Maytag
You must remove the rear control panel housing...
Remove some clips - and then remove the basin surround.
Here is a video that will help you out without having to type out the entire instructions. It is a general instructional that covers just about all the manufacturers.
Thanks for using FixYa!!
Aug 05, 2009 | Maytag MTW5900TW Top Load Washer
Washer fills but wont start
This happened to me today. I found the lid switch was loose and not engaging properly. Under the left side lid hinge, from the inside, I manually moved he switch arm, and the machine started working upon closing the lid!
Dec 11, 2013 | Maytag MTW5700TQ Top Load Washer
I fill machine with water but have top slam lid down and put some thing on top of the lid for laundry to start. now it just won't start. what do i do?
lid safety switch not engaging,had the same problem with my atlantis.turns out the plastic hinge pin bushings in the body of the washer where the lid is hinged. breaks apart.allowing the lid to come out of alignment. easy fix and the bushing is only about 2 bucks each at an appliance parts store...
Dec 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag glass lid shattered and I need to find A replacement and how to install
Unplug the machine. Pop the top using a putty knife to release spring clips between the top and front panel. Remove the hinge screws with phillips head screwdriver, pull the hinge straight out as seen on page 49 of this Maytag Bravos Service Manual
Jun 27, 2010 | Maytag Bravos MTW6600T Top Load Washer
The cycle stops at final rinse and water is left in the drum.............until I cycle the knob and depress to activate.
tighten the hinge screws on the top left of the lid. If that doesn't get it started hit the top to engage the lid switch which is hooked into the left hinge on a whirlpool. if its a maytag, its in the center of the rear lid and you must remove the consoles rear to access the lid switch
May 03, 2010 | Maytag MAV7580E Top Load Washer
Replacing lid on old Maytag toploader
pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Mar 09, 2009 | Maytag PAV2300 Top Load Washer
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
To replace part #1477, female hinge part for lid
Take a plastic putty knife and insert it under head. On each side.there is a push tab now where the 2 screws used to be push real hard in and the head will pop up
Dec 02, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
