Question about SanDisk Sansa e250 MP3 Player
When i plug in my sansa e280 it shows the booting screen turns white, and boots again
When i turn on my sansa e280 it shows the booting screen. then the screen turns white and tries to boot again, this continues unless you reset it. the same thing happens when you plug it into the computer. please help me!
  • 1 more comment
  • Douglas smith Jun 24, 2007
    i am the same person who posted this and i wanted to add that when i go to recovery mode, it only shows a versian file
  • Anonymous Dec 27, 2008
    Boots to sansa start up screen then goes white and boots again.....over and over again and again.
  • Anonymous Jan 12, 2009
    Me too, it continually goes white then reboots until I lock it...
  • 85 Answers
It sounds like you have a virus or some sort in it. If you still have a warranty send it back in and get a new one. It sounds like you have been doing exactly what you are supposed to be doing. The only thing that I could think of is that it is the motherboard. that is going to cost you about $91 Thank you, Connie
Posted on Jun 25, 2007
SOURCE:
Mp3 turns off/on wont charge
one of my friends had the same problem
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
I hope my post was helpful let me know!!!!
Mar 10, 2009 | SanDisk Sansa E280 MP3 Player
White Screen
if you disconnect your mp3 player, does the screen still appear white and can you turn it on or off?
i had the same problem, basically it freezes because it is busy downloading music or placing music where it is suppost to be. but if you cannot turn it off after you have unplugged it, you should take off the back cover and take out the battery. place the battery back in, and replace the cover and it should be able to turn back on without a white screen.
Sep 10, 2008 | SanDisk Sansa E280 MP3 Player
Microsd makes Sansa e280 screw up
Reset your player by slide and hold the power button for 10 seconds.
if that doesnt work let me know!
Mar 27, 2008 | SanDisk Sansa E280 MP3 Player
Restart
try doing this and let me know if it goes into recovery mode
1. with mp3 off slide the hold button to on so it locks
2.hold down record button on left hand side and keep held down
3. whilst holding record turn mp3 on still hold down record it should now be in recovery mode if your mp3 player gets this far then it can be fixed.
Once in recovery mode goto sandisk site and you need to goto downloads and download latest firmware for your make and model once downloaded it will talk you through how to istall this onto your mp3 player if you have any problems let me know ok
Feb 11, 2008 | SanDisk Sansa E280 MP3 Player
Repeating Screen HELP
I got mine to work.  This may only be applicable to the e200R (RHAPSODY) version of the Sansa.
Step 1:  Follow this link first and follow the directions:
http://www.anythingbutipod.com/forum/showthread.php?t=6214&highlight=SCSI
I didn't know where to get the ROM file so I left it out (I only created the sansa.fmt file got the MI4 file).  That brings me to...
Step 2:  Follow this link if you get a "Load main image failed Switch to recovery mode" error message:
http://real.lithium.com/real/board/message?board.id=Rhapsody_MP3_Players&thread.id=2403
It's very important that on step 8, after you turn it off and it is beginning to reboot, that you reset the Hold button so that it isn't showing orange anymore.
Not as hard as it seems!
Jan 10, 2008 | SanDisk Sansa E280 MP3 Player
My sansa wont boot up
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e280 8gb white screen with black spot
It sounds like some data corruption.
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa m240 MP3 Player
Problem
Maybe cause by a corrupt boot loader in the device, upgrading the firmware will help resolve this issue. Perform Recovery mode on the player. Enable Hold Switch + Press and hold record button + Press And hold menu or power button until it says on the screen welcome to recovery mode. Then download the sansa firmware updater on your computer and perform the update.
Oct 13, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e280 8 GB MP3 Player
Try connecting it to a PC to see if the data is read/writable.
Oct 06, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
101 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
