Question about Home
Maax elite 85 spa-heater isn't working
Heater is not working....no manual
2 Suggested Answers
aj53011
  • 6 Answers
SOURCE: Maax Spa Question
They should have an online manual of the website. Look that up or call costumer service
Posted on Apr 28, 2012
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
Display code p=
Make sure the spa is not on sleep mode "SLP" or economy mode "ECO". Without knowing what type of spa you have it's hard to diagnose but it's possible your pressure sensor or high limit sensor it temporarily out of balance. If that's the case, it will resolve itself. If the problem persists you have a faulty faulty pressure switch or sensor.
May 05, 2013 | Pool & Spa
Maax Spa Question
Apr 28, 2012 | Home
I have a maax spa, the pump and air lights are flashing, any ideas?
Maax, use a lot of proprietary components calling them is usually best.
But first there are two things which will shut a spa down like this are the main GFCI breaker or the Hi-Limit switch.
Reset or replace.
Jan 15, 2012 | Maax Home
Hi, I have a minimax 400 heater it will only bring the spa up to 85 degrees, the power light and temp light are on.
generally if you can only reach a temp of 85 or so you may have an oversized pump and the water is flowing too quickly through the heater. it may be necessary to install a manual bypass on the heater plumbing to divert the water enough to slow the flow through the heater down
Jun 11, 2009 | Pentair MINIMAX NT TSI IGNITER
Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
May 26, 2009 | Jandy Laars Lt 400,000 Btu Heater
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
