Question about Frigidaire FMV156DC Microwave Oven
All Frigidaire PLMVZ169GCC Microwave Oven problems
When set for 60 seconds the oven operates normally for about 30 seconds, then quits and it must be reset before operating again. Is this a magnetron problem?
  • Roger Oesterling Apr 21, 2013
    Problem turned out to be a faulty wall socket.
  • Official Brand Answer
  • 4,342 Answers
Hello Roger Oesterling - If the microwave is not heating properly, it could possibly have a faulty control panel, magnetron or an issue with the power supply. Contact a professional to move forward accurately for a proper diagnoses.
Posted on Jan 06, 2013
4 Suggested Answers
  • 1768 Answers
SOURCE: Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Posted on Mar 13, 2010
MicrowaveSvc
  • 9086 Answers
SOURCE: No readout on display for my plmvz169gcc
We regularly repair these oven displays / controllers for $39.95 nationwide. Details and a helpful video are here.
Posted on Jan 08, 2011
walesarumi
  • 6993 Answers
SOURCE: I'm looking for a repair
The truth is that the repair manual for your Frigidaire microwave is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the repair manual from them. They might give it to you or direct you to a dealer where you can get the repair manual.
This is the best you can do to get the repair manual you are requesting for.
Go to Frigidaire's website, check "Contact Us" and you would see their e-mail and phone number.
Additional information concerning your Microwave's Magnetron;
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged.
Good luck.
Posted on Jan 13, 2011
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
Plmvz169gcc lost power
The service manual is here.
It may be a defective 20A fuse, a blown magnetron temperature fuse, or a problem on the control circuit board, which can be economically repaired.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is off, you should be able to access the magnetron's temperature fuse for testing and possible replacement.
You can order parts from the Pros here.
Jan 10, 2013 | Frigidaire PLMV169DC Microwave Oven
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
No readout on display for my plmvz169gcc frigidaire microwave
Jan 04, 2011 | Frigidaire Microwave Ovens
My Frigidaire microwave model# PLMVZ169GCC does not heat food. It runs and makes a loud noise, the plate turns but does not heat up. It is only 2 yesrs old. Thank you for your help.
Intermittent load noise (usual intermittent pulse noise is exaggerated) and the food is not heating though everything else seems to opperate normally: The Triac or Diode is capute.
You need to replace this part (@$30), but first need to discharge the capacitor, which is dangerous. I am going to give it a "shot", and not a "shock", all the punn intended. I will use an long insulated screw driver to touch both of the 2/3 tines of the adjacent capacitor, which will give a load "POP!" 2-3x to insure the stored energy is diffused.
Then, hopefully, simply replace the longe wire diode.
TaDa!
Oct 22, 2010 | Frigidaire PLMV169DC Microwave Oven
My LG Microwave (LRM1250W) does not heat all of a sudden
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p]][p
Feb 17, 2010 | LG LRM1230W Microwave Oven
Microwave is new but it won't allow me to set the clock .
If you set the default for high heat, it will normally boil 8 ounces of water in 60 - 75 seconds.
Feb 04, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
389 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
