Question about Garden
Ariens 926le snowblower
I can spin augers by hand easily seem very loose but when the machine is running as they spin i can stop them by hand they have no tension on them
2 Suggested Answers
ToolBoxHero
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Auger on craftsman snowblower is very slow.how do i adjust idle
Not sure how long you have owned this machine but the auger does not turn fast. It 's job is to chop up the snow and push it back to the impeller. The impeller is the round plate in back of the augers that actually throws the snow out the chute. That turns fast. Check to be sure the shear pins are not broken. Shut the machine off. Wait for the augers to stop spinning and then try to turn the augers by hand. If they spin on the shaft then the shear pins are broken-replace them by using original equipment shear pins.
Dec 22, 2012 | Garden
I have an Ariens 1128 Snowblower. Here's the problem, everything seems to function fine, impeller spins, augers spin, howerver, when I put it into any real snow (more than 6-12 inches) the impeller and...
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
Feb 02, 2011 | Garden
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Jan 10, 2011 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Ariens 926LE snowblower won't engage forward or backwards. Running fine
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Garden Logo
399 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
