Question about ASUS Eee PC 1000HE Netbook
My Asus netbook will not get past loading windows
  • ASUS Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 01, 2013
When turning on the netbook, it load then the screen turns black for about 5-10 minutes before reaching the login screen. After logging in, the screen is just grey and stays like that. What's the
Try a system restore/recovery to a date before this issue. Have you done any hardware or software changes or updates? Graphics updates. Shut down, unplug, remove battery, plug in boot and follow this procedure: Please restart your computer, and hold down the F8 key before the Windows logo appears. On theAdvanced Boot Options select Repair your computer, and then press Enter. Select a user name, type the password, and then click OK. On the System Recovery Options menu, click System Image Recovery, and then follow the instructions. Take a look at this procedure from Asus suppot: http://support.asus.com/Search/KSearch.aspx?SLanguage=en&keyword=restore&ps=10&pn=1&st=knowledge
Dec 16, 2012 | ASUS Eee PC 1005HAPU17BU Netbook
Asus eee pc 1015x
Hello
The answer is YES. You can load Win-7 from an external DVD player, after making it as first boot device. You must have get DVD as first boot devce and the internal hard disc to second boot device. Click out all boot devices to none, by entering into the bios window. You can get the bios settings, by press and hold the "Delete" key of your computer, as it first try to load. OK.
Jan 28, 2012 | ASUS Eee PC 1015PXPU17RD Netbook
Its an asus pc 1018series need to re boot how can i perform it
Your asus netbook should have come with a White restore dvd. You will need an external dvd drive to use it.
Just put it in and it will boot to the disk and begin the restore process. Follow the instructions and you should do fine.
If it didn't come with a restore disk, You can Load XP or windows 7 from new media. Every driver you will need is provided at asus' website. You will need to load the xp version of the touchpad utility, as well as the chipset and acpi drivers, even if you choose to load windows 7.
I'm using I Eee PC 1000HE with 2 gig of ram and a single core Intel Atom n280 processor, and it runs windows 7 just fine. If you need more help, reply, and I will help as muh as I can.
May 09, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Do asus computers sold in the philippines only come with a trial version of windows because in canada its part of the purchase price. Is the computer shop scaming me to get me to buy the program...
Were you looking into purchasing an Asus netbook computer? If so, it's possible that it comes loaded with Windows 7 Starter edition. That's a pared-down version of the Windows 7 Operating System and is commonly sold with netbooks even in the U.S. Some customers prefer a full Windows 7 Operating System, like Windows 7 Home, but you should be able to purchase an anytime upgrade for less than the cost of the full Windows 7 Home software, so I'd recommend checking to see what the computer shop is interested in selling you: the Anytime Upgrade ($), or the full Win 7 Home ($$).
Jan 12, 2011 | ASUS Computers & Internet
After windows XP loads the mouse pointer freezes. It is not frozen, however, when the netbook is booting. it is an eee pc asus. thanks for any help
Start the laptop up in safe mode, remove the mouse driver and re boot the laptop. Windows will see there is no driver and load a fresh one. Assuming the driver that you have is the correct one, Asus use their own, it will work.
Dec 24, 2010 | ASUS Eee PC 1000HE Netbook
Netbook bios not fully acpi compliant
you are experienceing the blue screen of death, if these happened to yo have your netbook check by a qualified laptop tech to avoid any hardware damages
Nov 22, 2009 | ASUS Eee 4G Notebook
ASUS Eee PC 1000HE Netbook Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
