Question about 1995 B-2300 Combination Switch
Vehicle just dies when driving down the road...
My Mazda B-2300 with the 4-cylinder motor will just die on me while driving down the road or a a stop light. If you wait 3-5 minutes, it will start up again...If you drive a few minutes, shut the engine off, then try to restart right again, engine will turn over, but will not start...I have had it in at a Mazda and Ford dealer, but both say they cannot tell, as the computer has no memory to diagnose the problem...Will replacing the cam and crank sensors and the ECM solve this problem? Fuel pressure seems fine, so I am really stymied...
    Champion:
    Scholar:
  • 227 Answers
This behavior is typical of a CAM or CRANK sensor, even happens on many Mercedes Benze Models.
BUT, thee are other things that can cause it, like a failing fuel pump, even though the pressure is good.
Do just the sensors, don't replace the ECM yet. Would likely be a waste of money. if the sensors don't fix it, it might be worth trying. If an ECM is going bad usually you can twist it and tap on it and get the car to die, but on a b2300 that is not an easy task.
Posted on Nov 01, 2013
Rough idle stalls
sounds like major vacuum leak.
Aug 31, 2017 | Mazda Cars & Trucks
I drive a opel monza 1. 8 my car idle when i start it but when im on the road driveing its alright but when i stop by robots it dies start it will idle its only when i stop then it dies can it be my carb...
I had a diagnostic test @ 1place they said 2 cylinders were not giving full compression and that was causing the white smoke when it gets hot ,,,Place # 2 thinks the water pump is going bad ,,The coil suspecting may also be correct ..I drove it to wal mart and back ,,ran awesome ,,then got almost hot ,,here came that smoke again ,,No water in the oil ,,no leaks under the vehicle ?? Could this be a water pump issue ..Thanks
Nov 13, 2012 | Cars & Trucks
Drive vehicle down the road for 20 minutes and come to a stoplight engine stops when you take foot off gas peddle and go to apply brake. To keep vehicle from dying you have to hold the gas peddle down
Have you changed the timing belt? or timing belt guides? How many miles? This does not necessarily have to do with fuel.... Could have to do with air intake or timing as well....
Jun 12, 2012 | 1996 Dodge Ram
1996 chevy k1500 runs when idleing slight miss drives down the road fine but when comming to a stop it dies
When the light flashes it means a cylinder misfire, so you must check everything, spark, (first) injector fuel delivery intake manifold vacuum leaks and compression if not other problem accounts for the misfire.
Feb 04, 2012 | Chevrolet 1500 Cars & Trucks
While driving my 1993 929 down the road it just stopped running...had it checked out was told ti would be best to get a new motor and got a second opinion and was told to get a timing belt and fuel pump....
before going crazy , check the crank sensor out, a bad crank sensor will cause timing to be out of sync. more then likely engine will not start. or irregular rpm function if vehicle starts at all. it controls timing and sends info to pcm. if a crank sensor fails while driving the engine will die out. have scanned if check engine light is on. CPS symtoms are: car dies and won't re-start till it cools down, or won't start at all.
first of all, if crank sensor is ok, then you can check the timing belt.
Aug 24, 2010 | 1993 Mazda 929
Okay well when im driving down the road
sounds like the alternator is going bad. I had the same problem in a 94' Ford Probe. I replaced the alternator and it ran perfect. Hope this helps
Feb 21, 2010 | 1995 Mitsubishi Eclipse
I was driving down the road and my motor stopped
the alternator may of went bad and stopped charging so the car died when the battery went dead. Charge the battery and test to start with. Are you saying wont turn over ot turns over and wont start. If it turns over and wont start then it could be several things. Will need to get it diagnosed to be sure
Nov 16, 2009 | 1996 Ford Taurus
When slowing down & stopping 2005 Mazda tribute sputters and dies
Sounds like it could possibly be a vaccume problem, the computer sees that the vaccume has a low pressure and thus fludding the engine, or visa versa, it's seeing too high of a pressure and cutting the fuel comsumption to a minumum enough to make the engine sputter and die.. Does this happen when the cars in Netural or Reverse or Park? Just Drive?
Oct 19, 2009 | 2005 Mazda Tribute
My mazda mvp van keeps dying on me while in motion. It used to just die when I had been driving fast like freeway driving only and then coming into town and braking or slowing down. Now it is dying out of...
try replacing the fule filter and useing gas treatment to clean up injecters. also get a tuneup.i have had simaler probs with mine and have had success with these steps.
Nov 24, 2008 | 1992 Mazda MPV
1995 B-2300 Combination Switch Logo
112 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
David Burbee
David Burbee
JOHN LAPIER
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
