Manual need for a Nautilus NT-907 - Computers & Internet
How to replace cable on nautilus nt-cc1
Did you ever figure this out? I ordered the replacement cable, but can't figure out how to get it replaced.
Mar 26, 2013 | Nautilus Smith Machine
Lost directions. How do I get battery cover off?
Install manual for Kwikset SmartCode line is here.
If this helped, please vote. Thanks.
Jun 13, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Lock works in reverse
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Feb 19, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Nautilus problems
Hello:
I also have the Nautilus & the processor just isn't as fast as the newer units. You can adjust the track up mode to only refresh when the rotation of the map is over a cert amount, degrees, (resloution angle) if you have it set to a low value it will continually keep the route dead up & constantly refresh.
See section 4.3 Map orientation in the manual.
On the route reversal are you getting the pop up screen that alerts you that the route has been reversed?
I assume you have a manual?
I am actually contemplating selling my unit as I have a Garmin 478 from work & the screen is much easier to read in the bright sunlight. I had my Sitex on my Grady which had a bimini, but my Mako CC does not & the sunlight washes it out.
I'm thinking $375 for the whole unit with a wide area chart of MA.
May 14, 2008 | SI-TEX Nautilus NT GPS Receiver
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
