Question about ASUS M3A78-EM Motherboard
ASUS M3A78-EM stopped seeing second drive
I recently rebuilt my production box after several Seagate hard drive failures. Mother board is an ASUS M3A78-EM w/ an AMD quad core CPU running WinXP-x64. I upgraded to a 64 Gb SSD to dual boot XP & Win 8 (haven't installed Win 8 yet) w/ data & apps installed on a second Tb HD. Box has been up & running & today when I went to access e-mail, the app suddenly stopped & the window closed. The computer is no longer accessing the second drive. Is this an MB problem?
  • J Balmer Jan 03, 2013
    IF I power cycle the box, not restart but stop/start, the second drive is recognized. Sometimes briefly, once long enough to do a complete backup of all drives.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Update your drivers and check the cables out as well
Posted on May 27, 2014
xptareq2000
  • 1447 Answers
SOURCE: Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Posted on Jul 21, 2009
  • 5 Answers
SOURCE: sata/raid not working on ASUS M2N MB
You may need to set up the RAID array before it will be detected. Look in the BIOS and see if there is a way to set up the RAID array there. If there isn't, watch as the PC boots up and see if there is an option to go into the RAID settings before windows starts. You may need to actually create an array before it will be seen.
Posted on Nov 10, 2007
chinmay_lp
  • 271 Answers
SOURCE: PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Thanks
Posted on Mar 12, 2009
  • 25 Answers
SOURCE: i am installed windows 7 64 bit os in my system.
Download the drivers from Asus. http://support.asus.com
Also make sure in your Bios your HD audio is not set to front panel.
Posted on Jan 25, 2010
walesarumi
  • 6993 Answers
SOURCE: Recycle bin keeps filling up
Virus could be the cause of this problem. Try to perform system restore and observe if the error will go away or not. System restore, helps to reconfigure your computer back to the time when this error wasn't occurring.
To perform the restore, go to Start > All programs > Accessories > System tools > System restore.
Read the information on the system restore box before proceeding and follow instructions. After the system restore, the computer will be restarted.
If restoring doesn't solve the problem, please let me know so that I may direct you further on what next to do.
Good luck.
Posted on Feb 22, 2011
Need windows 8 drivers for mini bluetooth usb adapter
According to Sabrent's support site there are no drivers for Windows. The OS has native drivers. Windows 8 is not shown as a supported OS.
Feb 10, 2014 | Sabrent Mini Bluetooth USB Adapter...
When i power on my system it getting error of ' reboot or insert media device' what can i do? help me. motherboard is asus m3a78-em. win xp
Open the case and check the connections to your hard drive. You may have a faulty cable to the drive(usually the data cable) on the other hand your hard drive may have failed. Also check you don't have a disc in the optical drive(CD or DVD). Make Sure The Power Is Off before you open it.
Apr 04, 2013 | ASUS M3A78-EM Motherboard
Asus Mother board M4n68T-M LE V2 not supported seagate 1tb internal hard disk
It should support drives up to 2TB automatically unless you are using an operating system older than Windows XP. If for some crazy reason the board is limiting you it may be a glitch that is fixed by upgrading your Bios. You can download the latest Bios for your motherboard here:
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_LE_V2/#download
Jun 25, 2012 | ASUS Computers & Internet
Will it support Seagate Baracuda 500 GB SATA hard drive?
This board doesn't support the SATA interface hard drives, it only supports the older IDE interface drives
Jan 13, 2011 | AMD ASUS A7N8X-VM/400 Motherboard
No Boot , new P5QL-EM mother board
Check the heat sink ontop of your cpu sounds like bad connection and it will cause it to do as you describe
Aug 04, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
ASUS M3A78-EM Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
