Question about SanDisk SDCZ53-008G-A11 8GB Cruzer Pop USB Flash Drive Checkerboard
Unable to format
I can open the drive without formating if i click on format button they will tell unalbe formatt please help me
  • ummer_raez
    ummer_raez Jan 03, 2013
    PLease helm this one is not working and were is your home
  • Brian Sullivan
    Brian Sullivan Jan 03, 2013
    Which operating system ? w7 First, please disconnect all USB devices and then perform the following steps:Click "Start" button, type devmgmt.msc (without quotation marks) in the Search bar and press Enter. Click Continue if necessary. In Device Manager, double click to expand Universal Serial Bus controllers, right click on the Host Controller, click Uninstall and click OK.Repeat the step 2 to uninstall all items under Universal Serial Bus controllers. Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update / reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
  • SanDisk Master
  • 27,725 Answers
You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control. Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions. Make sure all 3 boxes are ticked full control change and read in windows 7. Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP. Click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer to open you should see your drive right click then select format another way Click start control panel administrative tools computer management disk management
Right click on your usb drive select format. If you need more help with this post a reply Hope this helps.
Posted on Jan 01, 2013
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I scanned my micro sd 1gb and 2gb cards with wormblaster and now the 1 gb reads 59mb and the 2gb reads 13mb and will not format does these cards have a MBR that maybe got wiped from the scan because both...
Instructions
Things You'll Need:
* SD card slot or card reader
1. Download SanDisk Formatting Utility
2. Open an internet browser and enter the URL for the free SanDisk formatting utility into the address bar (see Resources).
3. Accept the terms of use by clicking the button labeled "I Accept" at the bottom of the page.
4. Save the executable installation file (sdfv2000.exe) to the computer hard drive.
5. Open Windows Explorer and navigate to the installation file.
6. Double-click the sdfv2000.exe file to begin the installation of the software.
7. Click "Yes" to accept the terms of use for the installation package.
8. Verify the installation location and click "Next."
9. Select a Program Folder for installation and click "Next." The progress bar will monitor the installation.
10. Click "Finish." A text file containing notes for formatting software will automatically open.
Format SanDisk
11. Click the Windows "Start" button.
12. Click "All Programs."
13. Locate and expand the Panasonic link.
14. Double-click the program entitled "SD Formatter."
15. Insert the SanDisk card into the SD slot or card reader.
16. Click the top drop-down box in the SD Formatter interface to view a list of available drives on the computer.
17. Locate the SanDisk drive and select from the drop-down options.
Click the button labeled "Format" to begin the formatting process. A notification will appear to indicate the process has finished.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
Hi, ok so i plugged the 1 TB external hard disk in my mac book pro and i could open the files in it. But, i couldnt make changes on it, so can you please tell me how to make it mac compatible?? Thank...
The file system in which that disk is formatter isn't supported for writing in your mac.
You can't change the format without losing all the files so copy them on tour mac first then format it to FAT32 - go to Applications > Utilities > Disk Utility), the drive should be listed on the left side of the window. Click on it. Click the Erase tab. Make sure FAT is selected as the format and click the Erase button.
Sep 02, 2010 | Computers & Internet
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Windows was unable to complete the format 16gb kingston flash drive
windows was unable to complete the format flash drive
Apr 28, 2009 | Computers & Internet
Pen drive can't be formatted
Partition and reformat using Disk Administrator, which is found in Computer Management under Administrative tools.
Dec 31, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Kingston DTI/512
If you are unable to open it ,there might be a virus in you flash drive which is causing problem .
Solution:
Select the flash drive and right click .now select autoplay, a dialogue box will appear ,now select open to open it..
if you are unable to do this .
open my computer ,in the address bar ,click on the downn area button in address bar and select flash drive to open .if this also fails you have to format the flash drive ..
Try this in other pc if you are unable to do this on your computer ..now if you are getting same problem ,format it.
right click on it >select format >and format it to remove virus ...
If this answers your question please rate this as fixed.
THANKS.
May 08, 2008 | RCA (DVDCP33) Media
SanDisk SDCZ53-008G-A11 8GB Cruzer Pop USB Flash Drive Checkerboard Logo
234 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
