Question about Vizio M221NV 22 in. HDTV LCD TV
Vizio M221NV 22 in. HDTV LCD TV will not turn on with remote or outlet
No power lights come on.
tvtek
  • 1284 Answers
SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Posted on Feb 23, 2007
SOURCE: Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
Posted on Aug 17, 2008
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
Can not turn on TV since power outage yesterday.
You may have to ensure that the power outlet is ok. Try the TV on another power outlet. If it does not work, the TV might need servicing.
Aug 25, 2012 | Vizio M221NV 22-Inch Full HD 1080P LED LCD...
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
I switched my ps3 from one tv to my vizio, and the voices of the characters arent being heard, but all of the background noise is. i have it hooked up with an hdmi cable, and the video is fine. i checked...
Shot in the dark here, but sometimes HDMI cables get a little discombobulated... Try doing a hot plug by powering both the TV and the PS3 up and then removing the HDMI cable from both of them at the same time. Wait 1 minute, then plug them both back in at the same time. Good luck!
Jul 21, 2011 | Vizio M221NV 22 in. HDTV LCD TV
No problems. I just cannot find the instruction manual (can you send me one) and what is the best way to clean the screen?
http://www.vizio.com/m221nv.html
That's VIZIO's page for the manual. There are many good screen cleaners available and are sold at just about any electronics store. Usually 15-20. and all are about the same. Hope this helps.
Jul 07, 2011 | Vizio M221NV 22 in. HDTV LCD TV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I just bought a m221nv from ebay tv dealer an he said i could jus plug it in in my kitchen, bedrm or ? and watch it via my router cause it has wifi no need connect cable, antenna or anything but i cant get...
The wifi connection will allow you to access content via the Vizio Internet Apps (Netflix for example) but not tv broadcasts.
Your tv can access tv broadcasts (CBS, NBC, FOX, ABC) over the air but w/o an external antenna the signal and therefore the quality will probably be weak.
To access cable/direct tv/fios content you will need to connect the tv via a cable.
Mar 01, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio M221NV 22 in. HDTV LCD TV Logo
198 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
