Question about Technics SL-1210MK5 Turntable
Pitch Control Problems
I was at a gig last night and found that my pitch was extremely inconsistent. Today I turn it on and it seems to be working fine. I'm afraid I might encounter this problem again. Is there a reason why my pitch would jump form 33 to 45? It felt like I was holding down the 33 button and hitting the 45.
  • DjSatuRn Saturn Jun 26, 2007
    They are only about a year old. I took it to a tech to check it out and he said it's the pitch. I'm getting the pitch replaced. Hopefully that fixes the problem. I was going to go through the warranty deal but I think it might take too long to get it back. I need it by thursday.
    Thanks,
    DjSatuRn
    www.djsaturn.com
How old are your decks? common this problem,,,, sounds to me that you have a dodgy switch probably where you have been using the 45 to pitch up intermittently from 33 this isn't really an expensive fix, though if you have warranty use it! if you are going to attempt this your self parts are gonna cost about 15 bucks! but get a service manual and take the greatest of care heard a few horror stories which is why if you need an engineer to work it for you out side of the warranty you are probably looking at 70-80 bucks, i fix my mark 2's when i need to ,,,just be sure you have read up b4 you start! Kind Regards Junior J (Ministry of Sound) London
Posted on Jun 26, 2007
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
CDJ 1000MK2. CDJ pitch control is out of calibration. The pitch plays at zero when the slider is at what should be the slowest setting. How do i reset zero to the middle of the slider.
There is a fine adjust on the pitch control circuit board, however if it is staying at Zero at the extremes then it's time for a new pitch control :(
Jun 25, 2011 | Pioneer CDJ-1000 CD Player
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Pitch control drops drastic in middle of set
it sounds like the problem is the pitch control. this is a common problem that can be fixed pretty cheap check out 1200s website they offer alot of help and replacement parts for this issue.
Jul 05, 2009 | Technics SL-1210MK5 Turntable
Pitch problem out of nowhere!
HI Mattgood2
I believe this is a common problem more evident in decks that have a very hard life,
You pitch controls are probably due for replacements so I suggest you take then to the service agents to service them,
unless you know how to do the servicing
I grew up with Decks under my fingertips so I have seen this before and remember the only satisfing fix was a service and the pitch controls had to be replaced,
I thought I would have a go re-servicing myself and found far too many things to cover once the covers were off,
There are many things that need attention on the inside of these decks and the precise placement of each component is vital to the correct operation of this unit,peace of mind really
It takes a small amount of care to maintain these decks,
when they die or fail get a pro to fix the problem.
guess work only makes you look like an "Amatuer"
Please dont be offended (by my words) Ive done it too,LOL
I had a full dance floor and then nothing,the decks got replaced
What have you used to clean the pitch control sliders???
Aug 01, 2008 | Technics SL-1210 Turntable
Memory card
Hi I had the exact same problem!! I was using a 4 gig kingston memory card. I formatted the card to 2 gigs, it still had the same problem, then i erased all the movies and reformatted it again. It seemed to work fine after that. But i have requested a replacement handset anyway due to a battery problem when i turn off the phone the battery still wastes. I got a replacement today. and i also bought a 2gig micro to replace the 4 gig just incase the phone will be having the same random problems.
May 03, 2008 | LG KU990 Viewty
Pitch control center now 3.2% off center
maybe you should try a firmware update .follow the links on the vestax website about product support .
Dec 08, 2007 | Vestax Cdx05 Table Top CD Player CD Player
Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
Dec 08, 2007 | Vestax CDX-05 Turntable
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
Technics SL-1210MK5 Turntable Logo
118 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
