Question about Exercise & Fitness
Error6 on my treadmill
I have just turned my treadmill on after about a year of not using it and it was just moved. I plugged it in, and E6 error appeared. What does this error mean?
    Top Expert:
  • 12,223 Answers
Please see the problem and fix it. see the block diagram
circuit diagram attached.
Happy new year. God bless you
error6 on my treadmill - skfsyaaaaaelftksuqmcc
Posted on Jan 01, 2013
5 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: My Vision Fitness treadmill reads E6 when I turn
This just means that the elevation is out of range. It probably lost its signal when you moved it. The way to fix this is to recalibrate it. You can do an auto recalibration.
Posted on Nov 30, 2010
ercupa190
  • 12223 Answers
SOURCE: What could it mean if the treadmill just stops,
Dear Sir:
I will help you, inmediately.:
Try it with this step:
When machine is Stopped with various months, the dust+ corrosion in the electronic system can be affected.do it the following :
    • 1
Someconsoles require batteries. Check to see if this is the problem. If the consoledoes not use batteries, move on to Step 2.
    • 2
Removethe key from the console.
    • 3
Unplug the power cord.
    • 4
Removethe screws from the console hood and remove the hood.
    • 5
Turnthe pulley until the reed switch and magnet are aligned with a 1/8-inch gapbetween reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plugin the power cord.
    • 8
Reinsertthe key into the console.
    • 9
Runthe treadmill to check for a correct speed reading. This may take a fewminutes. Check this, and contact me, if you need some additional help. blessing , sincerely. E.CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 14, 2011
  • 39 Answers
SOURCE: my lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Posted on Oct 19, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a lifegear motorized treadmill. After using
1)Alternative: Elevation Out Of Range
2)tsu3fngh4aaaaasuvork5cyii=
Posted on Nov 03, 2011
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 04, 2014 | Exercise & Fitness
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
VISUAL FITNESS t97005 e6 ERROR CODE
LUBE THE deck belt, this happen because lack of maintenance, do ti
2( lube the rollers bearing too
3( test the input voltage motor, if there are the motor need repair
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 24, 2012 | Dmm Vision Fitness T9500 Treadmill
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
My lifespan treadmill has error code e6, what does this mean?
Oct 19, 2011 | Exercise & Fitness
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Error E6
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Exercise & Fitness Logo
284 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
