Question about Exercise & Fitness
Nordictrak e9 zl display not working correctly
No rpm or time or calories on display will count down or display. Heart rate monitor works ok. Manual suggests reed switch. I followed instructions but there is not enough play to move pedal disk away from inner workings without taking ff the pedal bar which it does not mention doing nonway to get to reed switch. New macine yesterday and afraid of going further and maybe invalidating warranty
    Top Expert:
  • 12,223 Answers
Please see the REED switch attached diagram, test for open or faulty, clean and tight very well the connector.
2) replace the batteries with FULL charge,with the same mark and polarities. Clean the contacts spring batteries very well, and try again.
see the block diagram
Happy New year ,God bless you
Nordictrak e9 zl display not working correctly - 1_1_2013_11_40_53_pm.gif1_1_2013_11_41_20_pm.gif
Posted on Jan 01, 2013
3 Suggested Answers
vpaaf
  • 115 Answers
SOURCE: When I turn on the treadmill and insert the key FF
what type of treadmill is it
Posted on Oct 10, 2009
  • 11 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
Posted on Apr 27, 2010
Need online manual for reebok heart rate monitor watch with calorie counter fit watch 10m
you should be able , look on back of watch, get name if manufacture and model number. if not you polar watches. may be same set up
Jan 16, 2012 | Reebok Fit Watch 10M Strapless Heart Rate...
Lost instruction and can't work how to get calorie count to start
In my tips and tricks page is a link to get a new manual.
If you have all of your settings correct for you (ht, wt, etc.) then all you should need to get a calorie count is heart rate and starting an exercise set. It has to be on and measuring to provide calories.
Mar 25, 2011 | Polar F6 Heart Rate Monitor for Women
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
OK.heart rate doesn't work right and the calorie burn is off too. Also, how can I set it for my body type so it can read the right calorie burn....the manual doesn't say. NOT HAPPY with this poduct!
Thank you for contacting FixYa.
This is a rather complex watch and the best person to contact on this one is going to be Timex themselves. Sorry.
You can contact them at this link:
http://www.timex.ca/en/contact.aspx
Best regards.
Jewel
Sep 02, 2010 | Timex 5G971 Heart Rate Monitor Ring Watch
The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Mar 24, 2009 | Reebok Fit Watch 10M Strapless Heart Rate...
How to figure calories burned
Try this link...I hope it helps. There is ann #877 cunstomer phone number also posted on this page.
http://www.iconservice.com/reebok/manuals.html
Dec 30, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
Bad counting
No, you're not doing anything wrong. I would trust the heart monitor, which gives you a better idea of what YOUR body is doing and not what the AVERAGE body is doing. Most pedometers also cannot distinguish running and walking, which have durastically different calorie requirements. It is most likely calculating the calories burnt if you were walking, not running.
Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Dec 17, 2007 | Garmin Forerunner 305 GPS Receiver
Exercise & Fitness Logo
80 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
