My Encore Haier washing machine's rinse and spin cycle have suddenly stopped working.
By unplugging the wash machine, it resets the operating system.
Posted on Jan 01, 2013
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Haier encore top load will wash but when it start to rinse want pump water out..I take drain hose lay on ground and it works fine whts the problem
there could be something stuck in the impeller of the pump not letting it spin , no power to the pump motor or the pump motor has burnt out or the impeller is loose on the pump shaft
Jan 09, 2016 | Haier Washing Machines
My spin cycle is not working
could be many things, motor, broken belt or drive gear, it is not easy to diagnose or fix if it's old get another, if not get a technician.
Jul 12, 2015 | Haier RWT150AW Top Load Agitator Encore...
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
My washer will fill and wash but when it gets to the rinse and spin cycle than it just stops and wont draiain
gwt450aw mine was washing but was not spinning and was loud like many others have posted. Seems the electronic drive motor had washer type ring inside the middle of the motor that was wavey from heat guess if happens over time. The friction was over heating the motor till it would stop working. Took that part off works fine. Once you've inside you can tell there is no need for it. Given the position of the motor. FYI the drive motor is under 10 year warranty from haier with proof of purchase for the date.
/uploads/images/6_9_2014_9_24_19_pm.jpg
Feb 04, 2014 | Haier GWT450AW Washer
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
468 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
