Question about Intel DG31PR Motherboard
Dg31 pr motherboard problem
I bought a gd31pr board and core2dua e7200 processor and 2gb ram. after 15 days it stop working it doesn't boot and nor gives the beep i removed rams but still no beep. i send it for warrenty claim when it came back its runing slow as hell.And sometimes lan card also stop working and after 1 or 2 days it starts working.please guide me what to do in that situation.
  • 4 more comments
  • linealaser Jan 20, 2009
    Hola, tengo un problema con la MB DG31PR de Intel trabaja pero despues de un tiempo (estuvo trabajando bien un dia y medio) se bloqueo, lleve la computadora a garantia y cambiaron la Mother Board peo el problema persiste.
    Corri el programa de diagnostico Sandra 2009 y me reporta que el VCore es mas alto del soportado por el procesador.
    Espero que alguien tenga resuelto el problema,
  • yepee9 Jan 21, 2009
    yes it shows correct cpu speed all bios options are default ( nothing messed up) there is only one ram of 2gb is installed.
  • yepee9 Feb 13, 2009
    already tried.
    i updated the bios but nothing changed.On intel site i read this:
    In Windows xp professional Intel® Desktop Boards that support Intel® Viiv™ processor technology may display a yellow exclamation mark within the Other Devices in Device Manager, indicating a problem with the LPC Interface Controller (example: Intel 82801 LPC Interface Controller).
    This may occur under the following conditions:
    * The operating system requirement for Intel Viiv processor technology has not been met. Intel Viiv processor technology requires Windows* XP Media Center Edition.
    * Intel® Quick Resume Technology (Intel® QRT) is enabled in the BIOS but the drivers have not been installed.
    To resolve this:
    If you plan to use Intel Viiv processor technology:
    1. Install the supported operating system - Windows XP Media Center Edition.
    2. Install the Intel QRT drivers.
    If you do not plan to use Intel Viiv processor technology:
    1. During boot, enter the BIOS setup by pressing F2.
    2. On the Power menu, disable Intel QRT.
    3. Press F10 to Save and Exit.
    But when opened my bios there is no such option to disable/enable QRT in power menu.
  • mohsen_molla May 13, 2009
    I am using also DG31PR motherboard with required cofigaration.system is fine when it is running but when i restart system take more time and showing INTEL image on monitor.
    Problem Solver:
  • 5 Answers
Update BIOS... Hope It'll work...
Posted on Feb 02, 2009
  • shovon_net Feb 15, 2009
    Try this link
    * Remove all the pci and pci-express cards
    * Now backup ur data and make a fresh install of windows, install all the drivers, specially the updated chipset driver,
    * Now see what happens... fresh install of windows should solve any hardware detection problem... I'd like to suggest u to try using windows XP SP2...
    * If there is no improvement...don't forget to try using an another RAM module...
    * If still no improvement then re-claim warranty...
  • 2,692 Answers
Does it show the correct CPU speed under My computer? Did you go through the BIOS setup screen and set everything up? Are you ram chips a matched set?
Posted on Jan 19, 2009
  • Thomas F. Schneider Feb 13, 2009
    The questions then become;" Do you Windows Xp Media Addition and/or do you have that yellow exclamation mark within the Other Devices in Device Manager?" If not it doesn't apply to you.  Another question that came to my mind "How many watt is your power supply and do you have an extra power lead that goes to the motherboard,for the CPU, by
    itself?" Just trying to help you think it through , here.
    Download the Specification Update(Jan 09) PDF file(Link below) and see if that applies to you. It talks about defects in design of your model(maybe,it had a chart), and updating the I/O controller hub, to overcome these defects.  A little over my head, I am afraid.
I bought a new Intel Board DG31 PR and i have a problem in audio
Check that mic is not kept on Mute. Usually after installing drivers, mic option is kept mute in most cases. (
Jul 23, 2009 | Intel DG31PR Motherboard
i have one solution to installed 2003 server in dg 31 pr
please open bios and hdd setting there are two option nativeor lagecy
you select legecy and then you r able to installed
Mar 25, 2009 | Intel DG31PR Motherboard
Current system is not an Intel(R) Desktop Board. -(A044412A)
Does'nt your MB CD have the drivers. Otherwise ask the supplier to provide you one....sodeep
Mar 18, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
No Microcode Update Loaded for Boot
It means the motherboard does not support that processor and you need to update the bios. You didn't say which Celcius you have, but the BIOS will have to come from Fujitsu.
Jan 23, 2009 | Intel Core 2 Duo Retail Boxed E7200...
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
303 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
