Question about Bulova Watches
Bulova Quartz Wall clock runs slow
Runs slow, chime does not agree with where hands are (ie: chimes when hour hand is not on 12) and sometimes minute hand does not move.
SOURCE: Chimes are nine minutes slow
Take the minute hand off and turn hand over. There is a brass bushing that attaches to the aluminum hand. Take a small screw driver and place in the square hole of the brass bushing. Turn either direction and test on the minute post of the clock. Keep adjusting until the clock chimes right on the 1/4 hour position. Make sure to put the hand back on the right 1/4 hour.
Posted on Apr 01, 2009
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
cmcduncand
  • 714 Answers
SOURCE: my new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Posted on Mar 19, 2010
Testimonial: "i will try this. thank you so much"
alpug
  • 1961 Answers
SOURCE: How do you set the
Please be guided by this rule:
1. Use the minute hand only
2. Never move the hour hand by itself to set the clock
3.Never move the hand while the clock is chiming or striking.
These are the instructions. Please be guided too that It will take up to twelve hours before the chime sounds completely synchronize with the correct time.
1. Open the clock door to gain access to the clock hands.
2. Set the day/night lever all the way up --the strike position-- if applicable. Also, if your clock has automatic chime sequencing, turn it off. Setting the time with the lever set on "auto" may damage the chime mechanism.
3. Move the minute hand backward to the correct time. Do not move the hour hand--it will move as you adjust the minute hand. Moving the hand backward removes the need to wait for the chimes to sound when you pass each quarter hour. The chimes automatically synchronize with the time. It can take up to 12 hours for the chimes to sound properly and in sync with the time
I hope these will help you in your setup while patiently waits until the chime sync with your time.
Thank you for using Fixya.
Alp
Posted on Sep 25, 2010
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
My Citizen Wall clock runs perfectly, however it does not chime the correct hour. How can I correct this, it is only 3hours off, but it it annoying
take both hands off the clock wait till it chimes then put hands back on to the time it chimes at, then adjust to correct time.
Sep 30, 2012 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    My new wall clock chimes 2 minutes BEFORE the
    R/
    David
    Mar 19, 2010 | Watches
    I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
    Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
    Feb 02, 2010 | Watches
    Watches Logo
    55 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
