Question about eMachines T5020 512MB DDR PC-3200 Desktop Memory
T5020 emachine seems to have dead power supply- how can I confirm?
I used this PC about 8 weeks ago then "parked" it for a while. When I tried to boot it yesterday nothing happened. I noticed when I pulled the power plug back out that the cooling fans surged for a split second but no other signs of life. A quick look inside didn't show any plugs unhooked.
  • eMachines Master
  • 27,725 Answers
If the PSU fans only work for a short time usually this means that the PSU is shot
If you suspect your power supply has gone bad, there are a few basic things you can do to test it. First, plug the computer in and try to start up the computer. If the computer can start up or shows signs of having power (the hard drives spin up, or the fans turn on) the power supply might be fine, and you may have an issue with your motherboard or RAM. If the computer won't start at all, open the case and then turn the power supply on and attempt to start the computer. Observe the motherboard to see if any lights turn. If no lights turn on and there is no sign that power is being supplied to any of your devices, there's a decent chance that the power supply has burned out. If your computer experiences periodic crashing, feel the case near the power supply to see if it is hotter than normal, and smell the air. If the case is much hotter than normal or you smell burning, your power supply might be overheating, and may be damaged. http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
hope this helps
Posted on Jan 01, 2013
Testimonial: "I have had random, frequent reboots with this PC and concluded it was the motherboard. This lead makes it look like my power supply was slowly dying and has finally seen the end. I ordered a new one today, Thanks!"
jgwhomeequip
  • 1902 Answers
SOURCE: T6534 WANT BOOT UP. SYSTEM RUNS INSIDE.POWER SUP?
You power ratings are ok on the main power supply. But you should check the volts on the internal and see what is happening.
Posted on Feb 05, 2009
Geekman
  • 32281 Answers
SOURCE: pc wont power up
Is there an on off switch on the back out the computer next to the main power socket? If so move it to the on position.
Check the mains lead and make sure it is firmly inserted in the socket.
When you press the front panel on button and it doosn't boot up and there is no light indicating power, then you have a faulty switch mode power supply.
Remove the switch mode power supply and replace it with a new one with the same wattage or greater wattage.
Posted on May 07, 2009
ssebata paul
  • 159 Answers
SOURCE: emachines won't turn on
remove the processor,ram for 30min and put them back
Posted on May 30, 2009
  • 551 Answers
SOURCE: my emachine will not boot up
try replacing the processor.
Posted on May 18, 2010
  • 154 Answers
SOURCE: died. nothing comes on, so not dead drive.
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Posted on Jun 23, 2010
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
I purchased a restart/restore disc for my emachine
yes either call the recovery hot line and confirm the build id on the disk match your pc . or get a replacement dvd drive.
May 13, 2010 | E-Machines eMachines Desktop PC
W2686 power supply problem?
Yes, any power supply will do as long as it fits in the case.
Either a regular power supply
or
a Micro power supply
They can be purchased online from Tigerdirect in any number of wattages.
Jun 14, 2009 | E-Machines eMachines W2686 PC Desktop
Not powering up .supply fine
remove your cmos / bios battery for 2 0r 3 minutes, reinsert it n turn on yor comp.
Apr 09, 2009 | E-Machines eMachines Desktop PC
Dead emachine t3104
In most cases this means that your motherboard is fried, but if you can get your hands on another power supply, try plugging it into your board just to be sure.
Feb 19, 2009 | E-Machines eMachines Desktop PC
Emachine w2646 won't power up
Put the hard drive in another computer as a slave drive or second on cable select. boot and then access the hard drive. Your data should be there.
Jan 08, 2009 | E-Machines eMachines W2686 PC Desktop
Cannot connect to internet after reinstall T5020
The reason you are unable to access the internet is most definitely your lack of a Ethernet/LAN driver.
When you reinstall windows all your previous drivers will be uninstalled and only the most basic devices will be recognized.
Hopefully you will be able to locate the Driver CD that came with your PC as I have been searching for a good 30 minutes and am yet to find the particular driver you are searching for.
Hope this information helps ;)
Blazamane
Jan 07, 2009 | E-Machines eMachines Desktop PC
About 2 weeks ago my sister's computer(emachines t3589) shut down I first thought that was the power supply,so I replaced it ,but the problem didn't go away,then I put the old power suply back on the...
The CPU fan is working?
The power button is working?
Did you connect the cables right?
If none of above fix your problem, seem to be a motherboard problem
Oct 04, 2008 | E-Machines Computers & Internet
EMachine T3025/Best Buy
get simple windows xp you just have to format deep with emachines as ntfs ive ran windows complete programs on emachines with out a problem and created straight recovery disk simple to be ran in windows safemode
now your hard drive
depending on which brand hard drive you have there is a couple out there that have data compression problems over 80 gig these harddrives over 80 gig have a crash ratio of 8 to 1 sea gate about 2 years ago had this problem dont know if they corrected it yet
quite possible your hard drive did not die at all but the power supply just didnt have the juice to push it check hdd by another source of power
May 12, 2008 | Computers & Internet
eMachines T5020 512MB DDR PC-3200 Desktop Memory Logo
102 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
