Front load washer
How do I drain the standing water I can hear inside drum?
    Scholar:
  • 133 Answers
Take the drain hose and lower it below the level of the drum.
Posted on Jan 01, 2013
Amigaman
  • 248 Answers
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
SOURCE: Kenmore Elite HE3 washer
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 82 Answers
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Posted on Jan 22, 2010
Macmarkus
  • 2605 Answers
SOURCE: My front load washer has a load clunk when the
Welcome to FixYa.
Based on your description "My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum"
my first suspicion would be a worn tub bearing, unfortunately all too common with those Frigidaire.
The tub bearing is likely worn, or the inner tub has broken apart.
You can check this by way of opening the door and grabbing the inner basket rim and moving up and down to feel for play...there should be zero play or zero tolerance in this bearing.
Second, since you`ve removed the back panel, grab the large pulley and try and move it back and forth or spin it with the belt off to listen for a grinding noise.
If it is indeed worn it will require practically the complete tub assembly ( rear wall with bearing and inner basket )...that is the least expensive and easiest fix at around $400 for the entire assembly.
example...
You can opt to change just the rear wall and bearing with the basket in separate pieces, but it comes in around $370 and still leaves you with pulling the old one apart to re-use the front shell.
Either way this is a fairly involved repair and even for an experienced tech like myself can take 60 - 90mins.
Let me know what you find and I'll do what I can to assist you.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
What does code f03 mean
An F03 error code on many front load washers indicates a failure to drain properly. You can usually clear this fault code by pressing the pause/cancel button. Next, check the drum for water. If the drum still has water in it, restart a drain and spin cycle. This should drain the water from the tub.
If your washer will not drain, check the drain hose for kinks or clogs. Make sure that the drain hose is not stuck more than 8 inches down the stand pipe.
If you do not hear your drain pump running, you may have a problem with your control or your drain pump. Also, if your pump is making a loud noise, it may be clogged. These problems would require service by a technician.
May 19, 2015 | Washing Machines
There seems to be water being retained in the machine
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there should be whats cauld a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.Alternatively water might be sigphoning back thru the drain hose into the machine.I hope this was helpfull.
Jun 01, 2010 | Samsung WF337AA Front Load Washer
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
WATER STANDING IN THE DRUM AFTER WASH CYCLE
can you see water in the tub, or do you hear water when you turn the tub? if you hear water when the tub turns, it is not water. the stainless drum has a liquid inside it for balancing loads. if this is the case, there is no problem. but if you see water in the tub that didnt drain, you need to check the pump and the hose from the pump to the outer tub. look for restrictions (coins, tooth pick, nail, ect.). also check the pump impellers to make sure none of them are broke, there are three plastic impellers. if any are broke, replace the pump. hope this helps you. let me know if you have any further questions. shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
