Question about Nintendo Wii Console
How to fit wii console to a Techwood TV
Have a Techwood Tv but can't see how to insert red yellow white leads from my Wii console
  • 35 Answers
SOURCE: hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Posted on Dec 26, 2007
SOURCE: Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Posted on Dec 30, 2009
fkuk
  • 311 Answers
SOURCE: hooking up wii and dvd to tv
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Posted on Dec 31, 2009
  • 10 Answers
SOURCE: i just bought a wii and someone gave me a tv to
Hey if you have another tv that'll work or there is a secret opening sloot that you can open up to find the jacks.Thats what I have on my tv.
Posted on Jan 24, 2010
SOURCE: Connected to tv but no Wii screen when we switch
Was trying to use the component option on the screen, as this had the red, yellow and white plugs shown. Eventually tried all the other options and found that it was plugged into Video 1! Works perfectly. Should try all the options on the TV!
Posted on Feb 02, 2010
I got a new nintendo wii today and everything works fine but the sound doesnt come on what should i do? i made sure everything was lined up right
The quickest thing you can try is to connect it to another TV and see if it works.
There are various methods for connecting the Wii to the TV. In the box you should have a component video lead with red, white & yellow connectors. These can be connected directly to the corresponding inputs on the TV or you can connect them to the SCART adaptor and then connect that to a SCART input on the TV. Try using the red, white & yellow leads directly if possible, just in case the scart converter is faulty. If you have more than one set of RWY connectors on your TV then make sure you are using the correct set (you might connect the yellow video to one set and accidentally connect the red & white audio to another set). If you are using the SCART input then try swapping to another input if possible.
Make sure the all the connections are fully pushed into the Wii and the TV.
Feb 16, 2011 | Nintendo Wii Console
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
New Wii is in black and white on my Samsung tv...any suggested fix?
    What to do will depend on how you're connecting your Wii console to your TV.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
something like this
Dec 30, 2009 | Nintendo Wii Console
Dec 29, 2009 | Nintendo Wii Console
Plugs on the Wii lead are red, white & yellow. Sockets on TV are red, blue & green, which goes where
The three on your tv are part of the component cable setup which contains six cables like here:
http://www.amazon.co.uk/gp/product/images/B000NUR582/ref=dp_image_0?ie=UTF8&n=560798&s=electronics
You probably have the normal red, white and yellow sockets elsewhere on your tv somewhere, try looking up the manual online.
Dec 27, 2009 | Nintendo Wii Console
Tv only has white and yellow inputs. tring to hook up wii that has green, blue, and red then red and white
Just plug the green Wii connector into the yellow TV input, and the white Wii connector in white TV input.
Hope this helps!
Sep 19, 2009 | Nintendo Wii Console
How to connect wii fit? no red white and yellow sockets on tv
i belive the wii fit connects direct to your wii console and console to tv
May 30, 2009 | GE 25GT240 25" TV
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
