Question about Sewing Machines
Singer industrial sewing machine 51w56 repair manual
SOURCE: Singer Sewing machine
I found the same numbers on my Singer, but learned that the 13608M is not the serial number. I finally found it on the bottom of the machine. It typically begins with either a single or double letter. You can find the Serial No. and Year of Issue at http://www.singerco.com/support/serial_numbers.html. You can also order a replacement manual. Another helpful site might be http://www.ismacs.net/Singer/singerdates.html.
Good luck.
Posted on Apr 06, 2008
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 5 Answers
SOURCE: Brother DB2-B755-3 industrial sewing machine
I have the manual in pdf form here
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 12, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
How to wind a bobbin on a singer model 2281B362
This sounds like an industrial machine. Go to the Singer website and click Support, then Industrial Product Support. They offer Parts Lists, Instruction Manuals and Service Manuals for industrial machines. If you can't get an instruction manual, you can often get a service manual.
Feb 16, 2017 | Singer Sewing Machines
Manual for singer 195KI industrial plain machine
How do you thread up and wind thread onto a industrial singer sewing machine model 195KI
Feb 05, 2013 | Sewing Machines
Operating manual for Singer Sewing Machine 132K6
- Go to: http://www.matparts.com/manuals.php
- Scroll down to the Newlong DD-5
- Download instructions/"View Manual"
- This is supposed to be the same (made in Japan) machine as the Singer 132K6
Aug 11, 2012 | Singer Sewing Machines
Singer sewing industrial model 20 U trouble shooting manual
nice industrial workhorse, you can dowload manusl from this
link http://wiki.techshoprdu.com/index.php?title=Singer_20u
thre is a parts, service and instruction manual here. Generally the service manuals assume a level of technical knowledge when doing the repairs on machines.
Hope this helps you out, please give 4 thumbs up if so. :-)
May 26, 2011 | Singer Sewing Machines
Can you please tell me where I can get a free copy of the Singer 491 D300AA sewing machine, thank you
You can find parts charts and instruction manuals for industrial Singer machines on their website parts.singerco.com.
Feb 25, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
105 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
